02-16-2016, 15:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Check log. SW told about problem exactly. Can try over service, but better first repair NV. |
02-16-2016, 15:48 | #3 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | DONE File looks Ok Operation : Write NV [ v1.14 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! GSM Phone detected! Write NVM Part #1 Ok! Write NVM Part #2 Ok! Write NVM Part #3 Ok! Write NVM Part #4 Ok! Clean DYNV Clean DYNV Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Repair Security [ v1.14 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Write new security data : IMEI1 : 355274061682425 IMEI2 : 355274062082427 Step #1 Ok Step #2 Ok Clean DIN Failed! Error code : 0x01 Error on step #3! PowerOn phone and check changes! Make Reset Settings from phone menu, if security info not changed! Write done! Elapsed: 00:01:04 Reconnect Power/Cable! BEST STILL IS THE BEST WHILE OTHER TOOL TOTALLY FAILED GREAT MR JAYDI BR S H P |
