11-11-2016, 09:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | SC7731C how remove google id Brand : Cell_C Phone Model : Deluxe Android Ver : 5.1 CPU/Processor : SP7731C_V1.0.0 SPD Project ver : Cell_C_Deluxe_IND_Ver2.0_160624_1200 SW Version : Cell_C_Deluxe_IND_Ver2.0_160624_1200 |
11-11-2016, 09:38 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I Know Already This Flash ID Not Now Have CM2 Support We Can Wait Here Hopefully Feed Back From JayDi
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
11-11-2016, 10:07 | #8 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
http://forum.gsmhosting.com/vbb/f296.../#post12153394 | |
11-11-2016, 10:31 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Tick "AltLDR" and repeat connect. If still no luck - try select SLDR, press PAC button in flash Tab , go to CM2SPD/Models/ select SC7731c_eMMC_V5.sldr. repeat operation again. |
11-11-2016, 10:44 | #13 (permalink) | |
still no luck SLDR Load Ok BB CPU : SC7731C SC773c Rev5 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Read FullFlash [ v1.23 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Open Port Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! | |
11-11-2016, 10:56 | #15 (permalink) | |
i try all one by one no luck Code: Card found: S/N : D76D8172 , v0134 Chinese Miracle II [SPD module] v 1.23 Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! SLDR Load Ok BB CPU : SC7731C SC773c Rev5 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! | |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
