05-21-2016, 08:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | SC7731C Supported? 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 750 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_7731C_W16.12.2_Debug Project : sc7731C_CP0_modem HWInfo : sc7731C_CP0_modem Compile : 03-11-2016 21:00:19 Phone Security Info : IMEI [1] : 866382011395998 IMEI [2] : 866382011895997 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.838 V Done |
05-21-2016, 10:35 | #3 (permalink) |
Member: 3468 Status: Offline Thanks Meter: 308 | Hi, Read Firmware not supported Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 748 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
05-22-2016, 15:18 | #7 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | info Code: Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp7731geahdplusoversea Model Brand : QMobile Model Device: scx35_sp7731gea_hd AndrVersion : 5.1 BaseBand CPU: SP7731GEA_HD CompileDate : 11/2/2015 2:55:57 AM Project Ver : QMobileW50_MP_10_30 Model Ext : QMobile W50 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Code: Start at : [5/22/2016 / 1:50:09 PM] Operation : Format File System / Reset Settings [ v1.18 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000138DF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [5/22/2016 / 1:50:26 PM] |
05-22-2016, 17:51 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That possible. When that will work well and as expected - we will release this. |
08-27-2016, 07:59 | #15 (permalink) |
Junior Member Join Date: Sep 2013 Location: Philippines
Member: 2026557 Status: Offline Sonork: [email protected] Thanks Meter: 0 | up u up.. this thread. |
