03-26-2016, 14:35 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1304552 Status: Offline Thanks Meter: 20 | sc8830 read fail i try to read with cm2 but fail cm2 support help log- Card found: S/N : Chinese Miracle II [SPD module] v 1.15 Operation : Check/Read Info [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
03-26-2016, 17:23 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as it is not SC8830, try as SC7731. There is normal and Alt LDR's. Also check amnual and info about how use PAC/SLDR as boot base and much other things. All in manual. On support. |
