03-24-2018, 17:48 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | [SC9850/SC9853] Intel+SPD : Free for all :D Just got a test sample and checked with current SPD module. As expected - main stuff is work. That mean - you not need wait/update anything. All what need, you have already. WorldFirst and BLA-BLA-BLA..... FRP reset On Latest SC9850/SC9853 : Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode! Mount : /cache Size : 0x0000000008F0D000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Code: Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : LEAGOO_T5c_OS2.1_E_20180310.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp9853i PacVersion : LEAGOO_T5c_OS2.1_E_20180310 File : fdl1-sign.bin File : fdl2-sign.bin File : isharkl2_pubcp_volte_K500_nvitem.bin File : prodnv.img File : secvm-sign.bin File : mvconfig-sign.bin File : mobilevisor-sign.bin File : u-boot-spl-16k-sign.bin File : ltemodem.bin File : ltetgdsp.bin File : ltedsp.bin File : pmsys.bin File : boot.img File : recovery.img File : wcnmodem.bin File : system.img File : userdata.img File : persist.img File : logo.bmp File : logo.bmp File : cache.img File : u-boot-sign.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1C records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SECVM Current File : secvm-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MVCONFIG Current File : mvconfig-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MOBILEVISOR Current File : mobilevisor-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_LTE Current File : ltemodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_LTE_TG Current File : ltetgdsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_LTE_LDSP Current File : ltedsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DFS Current File : pmsys.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WCN_MODEM Current File : wcnmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : CHARGE_LOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_LTE Current Part : l_runtimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot-sign.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:06:58 Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCORTM_17A_Release_415P_P6_Debug Project : isharkl2_pub_volte HWInfo : sc9853_modem Phone Security Info : IMEI [1] : xxxxxxxxxxxxxx IMEI [2] : xxxxxxxxxxxxxx BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.803 V Done Reconnect Power/Cable! That is just another proof about CM2 solutions made properly already and much time ago P.S. Latest SPD phones with embded battery HW reset can be made by LONG power on key hold. Tested on five different fresh samples. p.P.S. : Just finished latest MTK SoC's SLC NAND support. MTK/SPD v2.00 on way P.p.p.s : ooops, sorry, wrong section. |
The Following 65 Users Say Thank You to JayDi For This Useful Post: |
03-25-2018, 11:31 | #2 (permalink) |
Freak Poster Join Date: Jun 2011 Location: ilution
Member: 1597314 Status: Offline Thanks Meter: 116 | In my country much phone with spd 7731c not connect with cm2,phone can flash with Qgdp,firmware cpb extention. If u want ceck flash file u can ceck file for advan s4z, s5e 4gs,and other. |
03-25-2018, 11:32 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | hm... where are thousand comments from people who every day post "smart" comments about year 2030 etc. ? wakeup ! |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
03-25-2018, 12:13 | #7 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | @Jaydi What About Memory Tool Friend U Said Will Be Activated In Next Ver. (Coming Soon After 1-2 Weeks) With Support 16GB Or More Chip For Data Extract.... |
03-25-2018, 12:54 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
my misteck its not SBL 1 SBL2 its FDL1-sign.bin and FDL2-sign.bin | |
The Following User Says Thank You to sneha For This Useful Post: |
03-25-2018, 13:15 | #11 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | WOW... The best news one can get is that of what you said... "Just finished latest MTK SoC's SLC NAND support. MTK/SPD v2.00 on way" It is like message of Salvation. More elbows to you Mr Jaydi |
03-25-2018, 13:19 | #12 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | with pac file now set take boot Code: Loading : 1.2.pac CRVersion : BP_R1.0.0 PacCPUinfo : SharkLSGLobalMarlinAndroid5.1 PacVersion : 1.2 FastCheck : 0x00021637D0 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : SHARKL_DM_DSP-sign.bin File : WCN_fdl1.bin File : boot-sign.img File : CMCC_logo_8bit.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot-sign.bin File : SharkLSGLobalMarlinAndroid5.1.xml Load Ok! ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:19 Reconnect Power/Cable! |
03-25-2018, 20:42 | #15 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
And for specific device - need specific loader, signed for IT EXACTLY. Since I can't collect ALL phones over world - will be great, if peoples will post logs, pac or fdls for such phones. Will add them as sldr files or sepeate items in menu. | |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
