scatcheck error. I was trying to flash ZTE v809 with CM2 MTK module, and when i selected scatter file (which I have downloaded by searching over forums...), the following error shown: [SCATCHECK] : Missing File : C:\Users\sanbhi\Desktop\zte blade\cache.img I am sure it is because of the file problem. but although, SP flash tool flashed the phone and succeeded to give life to the phone. I just want to know, May I skip the scatcheck process to avoid error like this for flashing? |
Sometimes if firmware Not Read by CM2 & Firmware have missing File when indicated in scatter No chance to flash with it,whereas Flashtool can flash as well but can skip missing File. SKIP scatter check at your own Risk |
how to skip scatter check? |
Sometimes, you just need to flash without a box. Splash tool should be used then. It is not a must to use cm2mtk. In spflashtool, you can safely do safe-flash by selecting only Android partition. Then format with box after flash. |
