Old 02-23-2018, 13:10   #1 (permalink)
Member: 1132141
Thanks Meter: 22
scatcheck error.
I was trying to flash ZTE v809 with CM2 MTK module, and when i selected scatter file (which I have downloaded by searching over forums...), the following error shown:
[SCATCHECK] : Missing File : C:\Users\sanbhi\Desktop\zte blade\cache.img
I am sure it is because of the file problem.
but although, SP flash tool flashed the phone and succeeded to give life to the phone.
I just want to know, May I skip the scatcheck process to avoid error like this for flashing?
Old 02-23-2018, 13:43   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,353
Sometimes if firmware Not Read by CM2 & Firmware have missing File when indicated in scatter No chance to flash with it,whereas Flashtool can flash as well but can skip missing File.
SKIP scatter check at your own Risk
The Following User Says Thank You to Kirumira For This Useful Post:
Old 02-24-2018, 07:07   #3 (permalink)
Member: 1132141
Thanks Meter: 22
how to skip scatter check?
Old 02-24-2018, 08:01   #4 (permalink)
Member: 2500215
Thanks Meter: 233
Sometimes, you just need to flash without a box. Splash tool should be used then. It is not a must to use cm2mtk. In spflashtool, you can safely do safe-flash by selecting only Android partition. Then format with box after flash.
Page generated in 0.20279 seconds with 7 queries
