Old 06-21-2011, 13:50   #1 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Lephone A12 2GSM&CDMA how to do SPUnlock
phone is locked to operator
how to unlock
i read fullflash
here is log
COM7 [VCP0] selected
module v3.30
Action: "sp-unlock"
unlock method: smart fast
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5103:000E
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: MAUI.08B.W08.52.MP.V2
Version: K008
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35259504055073
connection Ok
detecting structure #1...
0 2 3 4 7 9 12 13 15 16 17 19 20 22 23 24 27 29 32 33 35 36 37 39error: detection failed (24 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
module v3.30
Device: Autodetect 6205-6239 NOR
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
enhanced security fix enabled
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2.BIN
project-id: MAUI.08B.W08.52.MP.V2, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2.BI
detecting firmware build...
firmware date/time: 2010-09-01 17-21
hw1: MAUI.08B.W08.52.MP.V2
hw2: 08B_HEXING25_08B_GEMINI
done
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Ru Gr Fr Es It De Tr Farsi Pt Ar Hi
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2.BI__ffs...
file saved: C:\InfinityBox\ChineseMiracle\HEXING25_08B_GEMINI_ PCB01_GPRS_MT6225_S00.MAUI_08B_W08_52_MP_V2.BI__ff s_20110621-173945.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 5 min 56 sec
Old 06-21-2011, 14:00   #2 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
how to attach flashfile
it lets only 456kb
Old 06-21-2011, 14:56   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What operator this phone is locked ?
if this phone is REALLY locked to operator:
- read full flash
- send full flash and problem description to [email protected]
Old 06-21-2011, 14:59   #4 (permalink)
Member: 130995
Hello,
- read full flash
Old 06-22-2011, 06:57   #5 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
sir i send flashfile to you [email protected]
Old 06-22-2011, 11:01   #6 (permalink)
Member: 130995
Thanks a lot, but what operator this phone is locked ?
На какого оператора залочен ?
Old 06-23-2011, 09:23   #7 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Телефон принесли из Казахстана
сам клиент не поднимает трубку
точно Казахский оператор
Old 06-23-2011, 10:43   #8 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
i talked with client
he used Beeline
Old 06-23-2011, 14:13   #9 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend @Namangan
Maybe You're From Russian & You mean This Phone ? Click Here
Old 06-24-2011, 05:23   #10 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Yes sir you right
thats the phone
so can we unlock it
Old 06-25-2011, 09:15   #11 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Sir we are waiting for your answer
Old 06-27-2011, 06:05   #12 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Again me is there any answer
Old 06-28-2011, 21:10   #13 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we are working under you file and problem
Old 06-29-2011, 08:35   #14 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Thanks sir we will wait for your answer
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.24250 seconds with 9 queries
