Old 11-18-2009, 05:09   #1 (permalink)
Member: 210669
Thanks Meter: 74
SCI Phone MODE: i9 3GS 32GB
i have a dead SCIPHONE I9, it was working ok before, but i flashed it with the wrong flash file, now the phone does turns on but the screen is white. the phone does not have hardware problem coz i got the phone n it was working ok
i flashed the phone with the following flash file
MT6225, 64MB
TELSDA25_07B_PCB01_GPRS_MT6225_S00.XMT_V2_6_AP0228 _256_64_25_MM2__iPhone-i9_64m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt.B 0M.bin
CAN SOMEONE HELP ME IN FINDING THE CORRERCT FLASH FILE
Old 11-18-2009, 18:21   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
you must show us your very first operation.
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
post this log here, we will advice flash file
Old 04-13-2010, 21:19   #3 (permalink)
Member: 1152295
Sonork: 19860704
Thanks Meter: 2
hello!
Can anyone help me? I need the same flash file 64mb
Sciphone mode: i9 3gs here is the name of the firmware
Thank you
KINGSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMIN I_W08_12.BIN
Old 04-14-2010, 10:29   #4 (permalink)
Member: 148515
hello!
This version we have a lot of 32mb flah files, but not 64m.
what problem do you have with your phone?
probably it can be solved by format FFS/IMEI restore?
Old 04-15-2010, 13:12   #5 (permalink)
Member: 1152295
Sonork: 19860704
Thanks Meter: 2
hello!
Hello
The problem is whit this phone is answers the call by it self.
I did everything restore to original settings but not work at all.
Old 04-17-2010, 12:06   #6 (permalink)
Member: 148515
hello!
but you try format FFS complete?
Old 05-28-2010, 19:56   #7 (permalink)
Member: 1152295
Sonork: 19860704
Thanks Meter: 2
Hello
Can you please upload this firmware in regular format? not for infinity
I see just have added to support site.
Thank you
X2501G_HW.2501G_0B_4050YUQ4_ALL_V1_3R
Old 05-28-2010, 23:31   #8 (permalink)
Member: 148515
hello!
this is infinity box user forum. are you infinity box owner?
Old 08-23-2010, 09:06   #9 (permalink)
Member: 1005552
Thanks Meter: 2
hi
i have a sciphone 3GS with six page menu.
when i install any .jar file, it install properly in java. my question is whether can i move the icon of the installed software on page? if yes, then please give the detail direction because i am completely new.
thanking you.
shekhar
Old 08-24-2010, 08:50   #10 (permalink)
Member: 148515
hello!
each chinese phone is different. you can try to make long press to this icon, it might be start moving
Old 09-05-2010, 08:40   #11 (permalink)
Member: 1005552
Thanks Meter: 2
hi
thanks for reply?
By making long press i can move the icone from here to there or one page to another page. but in the java folder when we long press in any icon, nothing happend. is there any other way to create shortcut of java programme which are presently installed in java folder or move the icon from java folder to desktop.
Old 11-02-2010, 12:28   #12 (permalink)
Member: 1433277
I've a Sciphone 3GS with firmware: XS3506C-GEMINI-WIFI-98W3M0AZBB5-PX-20100610 V0.14
Phone is in Good working condition but my friend accidentally deleted my settings icon, now I cannot change any settings. How do I get back the settings icon? Appreciate any advice from experience users.
Old 11-02-2010, 22:59   #13 (permalink)
Member: 148515
hello!
from my side i can only advice to make full backup and format_FFS it
Old 11-04-2010, 10:00   #14 (permalink)
Member: 1433277
Is there any software that can format_ffs this phone? Do I need special cable or hardware to do it. Can you let me know correct the procedure to get this done? Thanks
Old 11-04-2010, 11:33   #15 (permalink)
Member: 1043909
Thanks Meter: 51,293
Software is here: Infinity-Box - About
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following User Says Thank You to YellowBoss For This Useful Post:
Sci Phone i9+++ format ffs at-kom Infinity-Box 40 09-27-2011 12:15
Sci phone i9+++ firmeware needed please algeriano_19 Infinity-Box 18 04-08-2010 10:08
SCI Phone mode: i68+ Menus Problem dcoelho Chinese Models & Cloned Phones 0 03-09-2010 15:35
SCI Phone MODE: i9 3GS 32GB kava Infinity-Box 1 11-23-2009 19:05
Page generated in 0.40569 seconds with 8 queries
