06-29-2011, 08:57 | #33 (permalink) |
Major Poster Join Date: Nov 2009 Location: Hungary
Member: 1152295 Status: Offline Sonork: 19860704 Thanks Meter: 2 | Hello Please help me whit this phone. I cleared flash chip before i tried to flash. Phone cannot power on after write process. Thank you COM2 [VCP0] selected module v3.96 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: write flash NAND write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24__f ullflash_20110629-090834.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_T18_24.b in nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_T18.24 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_T18_24.b in nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BI N project-id: BR35_T18.24, ED1848C0 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_T18_24.b in nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BI N_C04818ED].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._BENRUI35_09 A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BIN_C04818ED_ .rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BI N_C04818ED].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_ 24.BIN_C04818ED_.rpl ==================== warning: unknown firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BI N_C04818ED Unknown firmware found (v.3.96, database date: 21.06.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24.BI N - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? aborted by user error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 1 min 32 sec Remove/Install battery now ! BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_T18_24__f ullflash_20110629-090834.B4M.bin - 4shared.com - online file sharing and storage - download |
Sci Phone i9+++ format ffs | at-kom | Infinity-Box | 40 | 09-27-2011 11:15 |
Sci phone i9+++ firmeware needed please | algeriano_19 | Infinity-Box | 18 | 04-08-2010 09:08 |
SCI Phone mode: i68+ Menus Problem | dcoelho | Chinese Models & Cloned Phones | 0 | 03-09-2010 15:35 |
SCI Phone MODE: i9 3GS 32GB | kava | Infinity-Box | 1 | 11-23-2009 19:05 |
