07-10-2009, 04:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: cebu city phillipines
Member: 229636 Status: Offline Thanks Meter: 48 | SciPhone i68+ needed help....... |
07-11-2009, 04:07 | #3 (permalink) |
Member: 229636 Status: Offline Thanks Meter: 48 | try to check this, am always use mode 2 in calibration phone but now not working what is the problem pls infinity support help me....... mode 1 without reverse calibration Code: Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: KINGSTAR25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35423602030694 connection Ok detecting structure #5 (mode-1)... 0 1 2 4 5 6 7 8 9 10 11 14 15 16 17 18 19error: detection failed (17 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! Code: Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: KINGSTAR25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35423602030694 connection Ok detecting structure #5 (mode-1)... 19 18 17 16 15 14 11 10 9 8 7 6 5 4 1 0error: detection failed (16 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! Code: Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: KINGSTAR25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35423602030694 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 done 209 byte(s) read reading data #2... reading data #3... can't read required data error: operation failed ! Finished, time used: 20 sec Remove/Install battery now ! mode 2 with reverse calibration Code: Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: KINGSTAR25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35423602030694 connection Ok detecting structure #5 (mode-2)... 18 17 done 210 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" UN-checked and try again 2. try another calibration mode Finished, time used: 19 sec Remove/Install battery now ! |
07-12-2009, 07:02 | #7 (permalink) |
Member: 229636 Status: Offline Thanks Meter: 48 | this mobile unit before i try to factory reset touchscreen working good then after i try to factory set touchsreen never work, then you tell me replace new touchscreen are you joking with me |
08-28-2011, 02:17 | #11 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1644065 Status: Offline Thanks Meter: 0 | I found this in another forum when i found a 68+ i lost 2 years ago in a couch and made the factory reset "mistake." "Hello, i have got the same problem, that occurs after factory reset and I SOVE THE PROBLEM AS FOLLOW !!!: Really after doing factory reset the touch screen is like virtually inverted, i explain : when you click on the Top right corner of the cell phone, it's react like you click on the Botom left corner.. it's like you turn your phone 180 degres. i flip my phone 180 degres, and i slide the bar at the supposed slide area and it's works fine. after you have to calibrate the phone, click on "Alarm" the area remplacement of "Settings", then click on "General call setting" replacement of "Pen Calibration". Then follow the pen calibration process.. I hope That my solution will help you...." I thank the internet and Google for archived forums. |
08-29-2011, 11:59 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, this method is known for us: TV Phone(Iphone clones) touchscreen stop working after fullformat - GSM-Forum |
SciPhone i68+ need pinout | bono32 | Chinese Models & Cloned Phones | 5 | 12-16-2010 10:39 |
China Sciphone i68 | Zelda42 | Chinese Models & Cloned Phones | 2 | 05-13-2010 21:13 |
SciPhone i68+ neede help | andy_lecnah | SpiderMan | 2 | 07-11-2009 11:52 |
I HAVE STRANGE PROBLEM WITH SCiPhone i68+ ! Please Help ! | Unlocker_001 | Infinity-Box | 7 | 06-29-2009 12:43 |
i need help with my sciphone i68 can anyone help me | spikejones | Sim Cloning and Scaning | 1 | 06-19-2009 19:52 |
