08-13-2008, 12:15 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | scny Esicsson cect k808 2sim 1000% ok software version: 1.14 cable type: 2x7 (L14D) platform: MT: MT62xx (autodetect) searching adapter at COM13... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:5 Tx:2 time required: 26 sec Power On ! Power Off ! Cable: 1x8 (L8A) Power On ! ==== log opened: [8/13/2008 4:36:03 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.54 S/N: ******** Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM13 [VCP2] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 207 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM13 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20080813-044435.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2201:18E59F00000000 Finalization Done Finished, time used: 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM13 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done Finished, time used: 88 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 8/12/2008-1:48:00 AM Continue with this imei ? COM13 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20080813-045511.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... 2 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 78 sec Remove/Install battery now ! |
Need mpeg4 necom n930 ve cect k808 pinout | tornado73 | Infinity-Box | 3 | 01-03-2008 12:09 |
hi pleas pinout cect k808 | bibooo | Infinity-Box | 1 | 01-02-2008 20:40 |
cect K808 2sim restart with sim | farshid-jan | Infinity-Box | 7 | 12-27-2007 10:44 |
need flash files china cect k808 mp4 | helloabuussama | Chinese Models & Cloned Phones | 0 | 12-10-2007 11:08 |
CECT K808 format FFS ok but callibration screen?????? | .::BHATTI::. | Infinity-Box | 5 | 10-24-2007 16:00 |
