SE J100i hang airtel Hi, I unlock sony ericsson j100i with infinty , after unlock hangs only airtel , again I try to unlock mobile not booting. Solution please regards |
hi, try to do formate ffs if not done u have to flash the phone. |
Dear Sir, It's cant be true that phone restart but can't boot after unlock. If phone can power-on this means that phone can be booted too, so, please, check your cable, check your phone hardware. Btw, what was phone state before unlock ? Did you checked phone before unlock ? Why you just say "not work" but not post operation log here for more details ? |
see the logs COM6 [VCP0] selected Action: format Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 01 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: R1E004 HW version: _NC2 LP ver: CXC1250384_lp_INDIA_R1E0 Flex ver: FFN_NC2_01_FILE imei otp: 354155016924338 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_354155016924338_20070927-134744.80E.bin error: wrong eeprom item detected, operation terminated imei eeprom: 354155016924338 Check Flash-2 Done Write... Write Done Finished, time used: 16 sec Remove/Install battery now ! before unlock phone was ok ( insert sim & working airtel sim) after unlock only airtel hang. I done many phones unlock j100i all are unlocked working fine. my cable allso good .it's need to flash? please give me solution |
You can try to flash phone with files from support area but make full backup before this procedure. |
thanks for good support , please let me know mobile is j100i . but reading logs files are showing j100 SW version: R1E004 LP ver: CXC1250384_lp_INDIA_R1E0 Flex ver: FFN_NC2_01_FILE my doubt is we have to flash j100 files are j100i files ? please tell me same files can be download & flash , I have back up flash & eeprom files. regards |
Hi, You can use J100 files for J100i w/o problems |
after flash phone status is "hacked" as your advice I try R1A002 ver, flash , repair IMEI & unlock phone still hacked. my request is , is it infinty working flashing for j100i? if it is yes, please give files detials to flash. regards |
hello! write repair eeprom, restore original imei ("restore" option ON) make unlock |
