11-11-2007, 12:47 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Poland WDA Age: 48
Member: 144165 Status: Offline Thanks Meter: 2 | SE J110i, which models are supported ? I can`t unlocking any of 10 phones j110i. All are form Germany |
11-11-2007, 12:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | All J110i/J120i software versions are supported ! All operators are supported ! You must explain what you tried to do and I'll tell you where you have made nistake and what you must to to fix yout mistake. |
11-11-2007, 13:25 | #3 (permalink) | |
Member: 144165 Status: Offline Thanks Meter: 2 | Quote:
Ok, I am a beginner so first tell me wich soft/update should I take to unlock J110i. I used moto 02 V1.44 Here is the log COM2 [VCP1] selected Device: Sony-Ericsson J110i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: KIM-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20071111-132310.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 30 sec Remove/Install battery now ! I put the card and : Insert correct sim card | |
11-11-2007, 15:00 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, You must use latest (latest means latest, not old) software from support area. Here is "sticky" therad about this: http:///vbb/showthread.php?t=454234 You must go to support area, download latest HModule update and use it. |
which models are support sd key restorable? | swechacnu | Universalbox | 3 | 12-23-2009 11:19 |
which models are supported with usb flashing on mt box plz help | aliakbar | MT-BOX | 1 | 02-27-2008 09:11 |
Which models are 100% supported without the use of TP ? | m_dige | Cruiser Suite | 7 | 02-21-2006 18:51 |
Received 3 samsung cables! Which models are supported? | m_dige | UFS2 + UFS3-Tornadoflasher | 5 | 02-21-2004 10:14 |
