03-01-2012, 05:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | Help, unlock HUAWEI G3610 i tried unlock G3610 with all method, but no success. Code: ==== [29.02.2012 12:18:47] ==== COM165 [VCP0] selected module v4.19 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:636F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C283SP02S Version: L75_HW ==================== New firmware found (v.4.19, database date: 21.02.2012): G3610_V100R001B001C283SP02S This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35761504780622 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... warning: wrong packet cs 972 byte(s) read lock[1] code: + 36242892 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 15 sec Remove/Install battery now ! ==== [29.02.2012 12:21:50] ==== COM165 [VCP0] selected module v4.19 Device: Huawei-G3610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:636F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.4.19, database date: 21.02.2012): G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S.BIN project-id: G3610_V100R001B001C283SP02S, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G3610_G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S__ffs... file saved: C:\InfinityBox\MModule\Huawei-G3610_G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S__ffs_20120229-122633.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................................................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 40 sec Remove/Install battery now ! ==== [29.02.2012 12:31:37] ==== COM165 [VCP0] selected module v4.19 Device: Huawei-G3610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:636F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.4.19, database date: 21.02.2012): G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: G3610MENGGU_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C283SP02S.BIN project-id: G3610_V100R001B001C283SP02S, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... ............................. lock area found ............................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................................................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-1 flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 8 sec Remove/Install battery now ! ==== [29.02.2012 12:34:08] ==== COM165 [VCP0] selected module v4.19 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:636F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C283SP02S Version: L75_HW ==================== New firmware found (v.4.19, database date: 21.02.2012): G3610_V100R001B001C283SP02S This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35761504780622 connection Ok 185 byte(s) read reading data... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... warning: wrong packet cs verification Ok done Finished, time used: 19 sec Remove/Install battery now ! |
03-01-2012, 05:38 | #2 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | link to download full and eeprom: Huawei-G3610 full_eeprom.rar - 4shared.com - online file sharing and storage - download |
The Following User Says Thank You to shuric For This Useful Post: |
03-01-2012, 05:44 | #3 (permalink) | |
Insane Poster Join Date: Feb 2012 Age: 35
Member: 1725478 Status: Offline Thanks Meter: 7 | Quote:
click servise tab and use unlock method read code i hope your problem solve \Br, kashifgsm125 | |
03-06-2012, 10:13 | #6 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | problem solved. flashed with G3610_G3610BEELINE_PCB01_GPRS_MT6223P_S00.G3610_V1 00R001B001C252SP02S_2011-06-07_En_Ru.B0M.bin from support. after this phone ask : Input NP code. i entered 12345678 and phone unlocked. Code: COM3 [VCP0] selected module v4.20 Device: Huawei-G3610 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Huawei-G3610_G3610BEELINE_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C252SP02S_2011-06-07_En_Ru.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:65D0:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: G3610SKY_PCB01_GPRS_MT6223P_S00.G3610_V100R001B001C177SP03S.BIN project-id: G3610_V100R001B001C177SP03S, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: 2088C4FFFF0043:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 32 sec Remove/Install battery now ! COM3 [VCP0] selected module v4.20 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:65D0:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C252SP02S Version: L75_HW 80 byte(s) read imei: 02508092000015 warning: wrong packet cs connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... warning: wrong packet cs 972 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 14 sec Remove/Install battery now ! |
02-10-2014, 09:04 | #7 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Uzbekistan
Member: 1791708 Status: Offline Thanks Meter: 21 | Quote:
02-11-2014, 02:18 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
