SE J132 Unlock Done Select : J132 Cable : C2500 Here is logs COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081128-210659.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 85 sec Remove/Install battery now ! Thanks to infinity Team . |
hi where can i find the c2500 cable |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
infinity is the best.............................................. |
hello masters pls am still yong to understand dis terms Rx/Tx/Gnd pins Pls can u masters help me to understand u well rx is what colour, tx is what colour, n gnd bcos i 20 pcs of j132 n 5 ot-s210 dont know how 2 make my own cable. pls help............... |
Hello, There is no colors for Rx and for Tx, forget about colors, colors is for babies. You must think about schematics and about professional solutions. You can see box RJ45 pinout in Infinity-Box Shell in "Documentation" page. Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
colors is for babies :D nice joke, i will sleep now br:) |
@cllins u have 20 pcs of j132 and ot-s210 for unlock.and u dont know TX/RX.in which country and city u r living.i think that city should need good repairman.because this is not difficult for unlock SEJ132 with infinity.other simple solution buy PINFINDER and forget about new cables. |
COM1 [Serial0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081129-200207.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 145 sec Remove/Install battery now ! made cable from motorola v3 100% .................... |
j132 done COM7 [VCP2] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081201-140750.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 76 sec Remove/Install battery now ! |
