Old 02-03-2011, 11:03   #1 (permalink)
Member: 1335674
se x10 processor 6235B 2 sim imei problem
Came the challenge does not work the second sim.
Spider was merged backup, then format - as a result do not work either sim,
* # 06 # - instead of imei void (on the same phone - 2 different normal).
Pouring some backup imei is not returned, spider or 2.68 or 2.69 or 2.70 Have not prescribe - error.
HyperTerminal port spider on the AT command writes ok, but the command change imei - error.
Infinity: "imei # 1 for 2-sim/one CPU " through type-2 ordered (type-1 did not see the type-3 wrote is not supported), recording "imei # 2 for 2-sim/one CPU " second imei written on top of the first.
COM9 [VCP0] selected
Module v3.26
Action: "repair imei"
recording method imei: Type-2
channel recording imei: imei # 2 for 2-sim/odin CPU
new imei: 355263410117969
Model: Autodetect 6205-6239 NOR
Checking data, wait ...
The device must be switched off!
Press and HOLD Power button now!
19200 autodetect
Initializing [6235:8 A04: 8A01] ...
CPU: MT6235
High speed downloads On
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19,200, wait ...
Release Power button!
The device is found, wait ...
Hardware: MT6235, E04
Date: 2000.00.00
Version: 1.0
Version: H3506_V1.7_RELEASE
Version: Z35_09A_HW
structure definition # 2 ...
1 4 5 8 September 1911 12preduprezhdenie: wrong packet cs
Ready
90 byte (s) read
imei: 35526341001696
Contact Ok
1 4 5 8 September 1911 12Gotov
90 byte (s) read
checking ...
the check is: 35526341011796
Completed, it took time: 17 sec
Unplug / plug the battery!
The result: one is prescribed and imei change, and the second is always empty, and as a consequence does not work the second sim!
Anybody got cured? And how? (MTK 6235B)
Old 02-03-2011, 20:18   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please try mode-2 for IMEI#2 change
Old 02-04-2011, 10:10   #3 (permalink)
Member: 1335674
Thanks, but it works well only through the mode-2.
I write imei#2 - change 1-imei, and 2-imei is empty! : (
Old 02-04-2011, 15:33   #4 (permalink)
Member: 1335674
up
Help me!
I have Infinity-box and Spiderman-box
Old 02-04-2011, 22:49   #5 (permalink)
Member: 148515
hello!
try IMEI changing via Bluetooth, Mode-1
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
Old 02-05-2011, 15:07   #6 (permalink)
Member: 1335674
Thank you all, Done!
Method:
through the engineering menu configurable UART:
1. TST-PS Config
UART2
AUTO
2. OPTIONS PS
UART1
AUTO
3. TST-L1 Config
NOT
below:
INFINITY-BOX:
Model: Autodetect 6228-6253 NAND
* recording method imei: Type-1 choose imei#1
phone off, press the RECORD and include your phone
1 imei - ready
recording method imei: Type-1 choose imei#2
2 imei - ready
Old 02-07-2011, 00:27   #7 (permalink)
Member: 148515
hello!
yes, engeneering menu is another option for making phone detected in mode-1.
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.16365 seconds with 9 queries
