02-13-2009, 12:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533827 Status: Offline Thanks Meter: 34 | SE Z250i hang solve by infinity.... action:flash with infinity firmware/flex/language pack COM4 selected module v1.30 Device: Sony-Ericsson-Z250i "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89880A00010001:89880A00000000 flash: Intel Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb software version: 1630-000 software version: ABU-3- Check hardware done Read data ... reading Sony-Ericsson-Z250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-Z250i_eeprom_calibration-1_20090212-171931.80E.bin Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Write ... Area: Firmware flash: 89880A00010001:89880A00000000 Write: Firmware Area: Flex flash: 89880A00000000:89880A00000000 Write: Flex Area: Language Pack flash: 89880A00000000:89880A00000000 Write: Language Pack Write done Finished, time used: 1522 sec Remove/Install battery now ! thanks infinity team....... |
The Following User Says Thank You to bhongskie12 For This Useful Post: |
Vodafone 125 Restart Problem Solved By Infinity | zeel_zeel | Infinity-Box | 4 | 07-23-2010 08:25 |
D807 start up hang solved by this opti flash tool | aiyon_861 | Samsung Flashers, Software, Firmware. | 15 | 04-05-2009 10:11 |
e101 permanent blocked solve by infinity | ricson | Infinity-Box | 8 | 11-09-2008 01:11 |
ZTC 6618 hung solved by infinity | tahod | Infinity-Box | 2 | 09-23-2008 23:17 |
<< LG C1150 Hang repaired by Infinity >> | zeel_zeel | Infinity-Box | 1 | 08-10-2008 00:37 |
