10-08-2008, 20:59 | #1 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | SE Z250i problem here is log: flash: 20881CFFFFFFFF:20881C00000000 flash: ST Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb version sw: 1410-000 version sw: ABE-3- Check hardware done Read data... reading Sony-Ericsson-Z250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-Z250i_eeprom_calibration-1_20081007-000754.80E.bin Read data done Check data... Check data done Writing... Area: Eeprom flash: 20881CFFFFFFFF:20881C00000000 Write: Eeprom error: no any expected answer error: flash write error: 07FFE000:00002000 error: no any expected answer error: flash write error: 07FFE000:00002000 Writing fail Finished, time used: 227 sec Remove/Install battery now ! Tried all speeds and ports, same... |
10-08-2008, 21:31 | #3 (permalink) |
Member: 4989 Status: Offline Thanks Meter: 13 | Someone tried to unlock it with infinity. I don't know the steps he made, but I have first backup made by program, I thought I could revive it, but... I will find out more info tomorrow from customer. |
10-09-2008, 08:38 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If flash chp can not be written it may be hardware problem. Use latest Infinity-Box software. Try to write firmware into phone, let's see results. |
10-12-2008, 19:56 | #7 (permalink) |
Member: 4989 Status: Offline Thanks Meter: 13 | Well, used latest sw, here is log writing main lp flex, repair flex + eeprom, always same error writing eeprom: COM16 [VCP2] selected Device: Sony-Ericsson-Z250i "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 20881CFFFFFFFF:20881C00000000 flash: ST Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb version sw: 1540-000 version sw: ABE-3- Check hardware done Read data... reading Sony-Ericsson-Z250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-Z250i_eeprom_calibration-1_20081012-213132.80E.bin Read data done Check data... Check data done Writing... Area: Firmware flash: 20881CFFFFFFFF:20881C00000000 Write: Firmware Area: Flex flash: 20881CFFFFFFFF:20881C00000000 Write: Flex Area: Language Pack flash: 20881CFFFFFFFF:20881C00000000 Write: Language Pack Area: FFS/File system flash: 20881CFFFFFFFF:20881C00000000 Write: FFS/File system Area: Eeprom flash: 20881CFFFFFFFF:20881C00000000 Write: Eeprom error: no any expected answer error: flash write error: 07FFE000:00002000 Writing fail Finished, time used: 1359 sec Remove/Install battery now ! Phone still dead, not powering on. Phone died during unlocking process at a customer of mine. |
10-12-2008, 21:41 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read eeprom and send original eeprom and current eeprom files to [email protected] to check. Ca not promise anything but will try to check it. |
10-17-2008, 19:28 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Files was checked, both eepom files seems to be Ok, so I don't think that phone state will be changed even if you will be able to write eeprom back. Can not say why eeprom can not be written. Anyway, I have sent you back two eeprom files in plain bin (non crypted) format, if any other tool can use these files try to use it. |
how to revive dead SE Z250i with infinity? | kevin168 | Infinity-Box | 8 | 12-10-2009 14:41 |
Z250i problem | aymano | Infinity-Box | 1 | 11-10-2009 13:06 |
Z250i problem | aymano | SETool2 | 0 | 11-10-2009 11:44 |
SE Z250i hang solve by infinity.... | bhongskie12 | Infinity-Box | 1 | 08-04-2009 05:51 |
strange SE z250i | jcosta | Infinity-Box | 3 | 06-29-2008 23:56 |
