send+receive error CM2MtK Please little help here would be great. send + receive error. ISO7816 error 0x6E00 class not supported always appear everytime i open cm2mtk software which 3 days ago it was working fine. |
=== DongleManager [Infinity] v1.72 [5/28/2019 2:53:54] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000AAD77F634082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): E07EAAD7 Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0137 === DongleManager [Infinity] v1.72 [5/28/2019 2:54:02] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000AAD77F634082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): E07EAAD7 Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0137 => Online Service Account: http://www.infinity-box.com/service - Username: 00E07EAAD7 - Password: ..... |
USE PC Back Port Or Use Good Smartcard Reader:);) |
You have to replace ini file search that file in infinity section & replace |
You can reinstall your mtk mt2 into local Disk C / program file. And see results. |
I already replaced using the latest ini file and issue is still the same I havent tried to change the installation folder but i will try that suggestion i am using the latest cm2mtk software version 1.58 |
Most IMP Don't Connect Other Tool While Run CM2 Sometimes Other Dongle Conflict. Try It If Same Try With Another Reader... |
I dont connect any other tool while running cm2.Just the box and i have no other card reader only alcormicro card reader. Sometimes the software is working but suddenly the "send + receive error. ISO7816 error 0x6E00 class not supported" appears in no time. |
also you can try to insert card into another reader or box. result ? |
"SCardTransmit error" SmartCard API error #1117 The request could not be performed because an I/O device error |
Another way - use CM2MT2 software. result ? |
