Old 05-27-2019, 20:52   #1 (permalink)
Member: 2732211
Thanks Meter: 4
send+receive error CM2MtK
Please little help here would be great. send + receive error. ISO7816 error 0x6E00 class not supported always appear everytime i open cm2mtk software which 3 days ago it was working fine.
The Following User Says Thank You to poginghen420 For This Useful Post:
Old 05-27-2019, 20:54   #2 (permalink)
Member: 2732211
Thanks Meter: 4
=== DongleManager [Infinity] v1.72 [5/28/2019 2:53:54] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0000AAD77F634082
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): E07EAAD7
Firmware version: 0137.02
"UK Edition" status: On
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v.0137
=== DongleManager [Infinity] v1.72 [5/28/2019 2:54:02] ===
Searching...
=> Activations:
=> Online Service Account: http://www.infinity-box.com/service
- Username: 00E07EAAD7
- Password: .....
Old 05-27-2019, 20:54   #3 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,296
USE PC Back Port Or Use Good Smartcard Reader
The Following User Says Thank You to hitech care For This Useful Post:
Old 05-27-2019, 20:58   #4 (permalink)
Member: 2732211
Thanks Meter: 4
i've just bought it only this month and im not using this very often
Old 05-27-2019, 21:02   #5 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 109
You have to replace ini file search that file in infinity section & replace
Old 05-27-2019, 21:50   #6 (permalink)
Member: 2812901
Thanks Meter: 409
You can reinstall your mtk mt2 into local Disk C / program file. And see results.
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 05-28-2019, 00:03   #7 (permalink)
Member: 148515
Thanks Meter: 15,722
What is the installed cm2mtk software version ?
Old 05-28-2019, 02:32   #8 (permalink)
Member: 2732211
Thanks Meter: 4
I already replaced using the latest ini file and issue is still the same
I havent tried to change the installation folder but i will try that suggestion
i am using the latest cm2mtk software version 1.58
Old 05-28-2019, 06:08   #9 (permalink)
Member: 1834832
Thanks Meter: 1,296
Most IMP Don't Connect Other Tool While Run CM2 Sometimes Other Dongle Conflict.
Try It If Same Try With Another Reader...
Old 05-28-2019, 18:58   #10 (permalink)
Member: 2732211
Thanks Meter: 4
I dont connect any other tool while running cm2.Just the box and i have no other card reader only alcormicro card reader. Sometimes the software is working but suddenly the "send + receive error. ISO7816 error 0x6E00 class not supported" appears in no time.
Old 05-28-2019, 19:01   #11 (permalink)
Member: 2732211
Thanks Meter: 4
Please help here the "send + receive error. ISO7816 error 0x6E00 class not supported" always appear in the middle of no time. While flashing while reading.i cant finished anything..
Old 05-28-2019, 19:17   #12 (permalink)
Member: 148515
....Sometimes the software is working but suddenly the "send + receive error. ISO7816 error 0x6E00 class not supported" appears in no time.
remove card from reader, clean contacts, insert card back.
also you can try to insert card into another reader or box.
result ?
Old 05-28-2019, 19:41   #13 (permalink)
Member: 2732211
Thanks Meter: 4
Unhappy
result ?
Still the same sir my infinity box is only 1 month old. Just don't know what to do. Updating shell is working good read s/n using dongle manager is working normal but when i open cm2 software send+receive error always appears
Old 05-28-2019, 20:05   #14 (permalink)
Member: 2732211
Thanks Meter: 4
Unhappy
result ?
Sir this message also appears
"SCardTransmit error"
SmartCard API error #1117
The request could not be performed because an I/O device error
Old 05-29-2019, 06:16   #15 (permalink)
Member: 1043909
Thanks Meter: 52,180
If you have this error with v1.58 only you should delete CM2MTK folder, install CM2MTK again.
Another way - use CM2MT2 software.
result ?
Page generated in 0.37945 seconds with 7 queries
