Old 02-21-2017, 23:30   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Support Area access procedure improved
- Login to Infinity Online Service (IOS)
- Click to menu "Support & Downloads" and once again to "Support & Downloads"
- Click to link with Support Area that you want to access
NOTE: Different Support Area links will be available depends on your active Services
Infinity-Box Shell is not required any more for Support Area login !
How to access Support Area
Sign In to your IOS Account
Click to Downloads and select Support Area that you want to access
The Following 45 Users Say Thank You to YellowBoss For This Useful Post:
Old 02-22-2017, 05:25   #2 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
will not required or will not work anymore ?
shell is easy way to enter in support area so please do not terminate if you are going to do so.
hard to remember multiple logins.
The Following 10 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 02-22-2017, 07:44   #3 (permalink)
Member: 1043909
Shell works for now.
Actually new method is more easy, because you need to know only one password - password for IOS.
With this password you can login to IOS and after that - you can access Suport Area with one click even without dongle.
The Following 10 Users Say Thank You to YellowBoss For This Useful Post:
Old 02-22-2017, 08:12   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
Instruction moved to first post
The Following 7 Users Say Thank You to InfinityHelp For This Useful Post:
Old 02-22-2017, 09:23   #5 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
After login iam Getting account is not active iam having Support
Activation 1: Infinity-Box/Dongle; ; Firmware Version: 0135; Registered: 2015-06-05; Expired: 2018-10-21; Support: Active
Still this error
The Following 2 Users Say Thank You to princesaddam For This Useful Post:
Old 02-22-2017, 09:36   #6 (permalink)
Member: 355782
Thanks Meter: 1,265
its working...
The Following 6 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 02-22-2017, 10:25   #7 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
It will be better if there is one button in software to click to go to support area.
The Following 9 Users Say Thank You to Shubhanshu~ For This Useful Post:
Old 02-22-2017, 14:16   #8 (permalink)
Member: 1043909
Still this error
Please close browser, login to support again and try to login to Server #1
What is the result ?
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 02-22-2017, 14:19   #9 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
same error i try to do it with Shell also but same
The Following 4 Users Say Thank You to princesaddam For This Useful Post:
Old 02-22-2017, 14:19   #10 (permalink)
Member: 1043909
its working...
Can you login to BEST support area well from IOS ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 02-22-2017, 14:20   #11 (permalink)
Member: 1043909
Do you mean you have the same problem with Shell also ?
Old 02-22-2017, 14:22   #12 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Yes sir same prblm with shell also
The Following 3 Users Say Thank You to princesaddam For This Useful Post:
Old 02-22-2017, 14:32   #13 (permalink)
Member: 355782
Thanks Meter: 1,265
yes both links for support working fine.
The Following 4 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 02-22-2017, 14:35   #14 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Will be more good if have Support Access button in Every infinity modules
so it will more friendly and easy !
The Following 7 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 02-22-2017, 14:43   #15 (permalink)
Member: 1043909
Probably this idea is good for the first look but we do not want to make more and more the same buttons in all exe. Just imagine what should we do if we need update support area. Update then many different exe files with new method, with new server address etc. ?
Sorry, but it will be no such button in all exe.
The Following 6 Users Say Thank You to YellowBoss For This Useful Post:
Page generated in 0.32661 seconds with 10 queries
