Server answer:[0031] Dongle identification data damaged === DongleManager [Infinity] v1.70 [5/14/2017 13:37:04] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 1 HWID: 00014EDCFF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 023A4EDC Firmware version: 0134.02 === Process started: 5/14/2017 13:37:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
no reply infiniy team wake up bro.....i need your help please lead meeeeeeeee |
Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
I know what did i said bro i need the solution can u provide me the solution ???? |
Sir again the same problem rise up.if u dnt want to solve then let me know .then i will have to arrange alternative....thnx |
Sir. You must find your INITIAL thread ! You have an answer there. Should I search that thread for you ? |
http://forum.gsmhosting.com/vbb/f296...nosis-2223047/ thanx sir............................actually im willing to repair this box...for me box is more reliable comparatively then dongles |
thanx sir. please check your first thread for an answer. |
sir plz solve my problem === DongleManager [Infinity] v1.70 [5/4/2018 17:36:07] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000092D87CF94082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): CF3092D8 Firmware version: 0135.02 === Process started: 5/4/2018 17:36:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware |
Hi Infinity Team My Infinity is not open show WARNING. DONGLE MISCONFAGRATION HELP PLEASE |
What to do - http://www.infinity-box.com/support/?r=4 Waiting for your result, information and fault.bin file. |
i am also face this problem. can you fix your problem? |
- Connect dongle/box to PC - Run DongleManager.exe - https://www.infinity-box.com/support/?r=5 - Make "Read Serial Number (S/N)" DO NOT send screenshot/video but copy/paste text from software window ! |
