10-29-2014, 15:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | InfinityBox_install_CM2MTK_v1.04 & 1.05 ERROR 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
10-29-2014, 15:42 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @amancommunicati Thank you very much my Dear Friend for your information ! All our prorgammers now working to amke a new software that can satisfy YOU for 100% ! Please be patient, software programming process is not a potatoes trading ! |
