12-06-2008, 14:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | sfr 111 succefull unloked with infinity+pinfinder sfr111 same pinout with zte 225 ... TX:1 RX:2 GND:3 .... her's a log : COM7 [VCP0] selected module v1.57 Device: SFR-111 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: SFR-P108A2FMV1.0.0B03 04.12.00 18.26.11 08.02.00 Aug 28 2008 SFR Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-static_20081206-142551.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-security_20081206-142552.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-complete_20081206-142554.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_lock-area_20081206-142556.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! thanks a lot infinity team .... |
The Following 4 Users Say Thank You to noure30 For This Useful Post: |
12-06-2008, 14:46 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
this team is really GREAT... Good lucks to Them... thanx for test report... | |
02-21-2009, 05:59 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | COM16 [VCP0] selected module v1.60 Device: SFR-111 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: SFR-P108A2FMV1.0.0B03 04.12.00 18.26.11 08.02.00 Aug 28 2008 SFR Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-static_20090221-095623.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-security_20090221-095624.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-complete_20090221-095626.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_lock-area_20090221-095630.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! tested great work by team |
The Following User Says Thank You to gsmkiller173 For This Useful Post: |
02-21-2009, 17:52 | #5 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
02-17-2010, 12:04 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | successfully unlock sfr 111 noir i got successfully unlock sfr 111 noir |
The Following User Says Thank You to umarmsn For This Useful Post: |
ZTE SFR 111 unlock done by infinity | BouRRi_GSM | Infinity-Box | 3 | 03-13-2015 18:06 |
sfr 111 100% unloked by infinity tkenks | redouane2007 | Infinity-Box | 0 | 04-26-2009 15:59 |
sfr 111 noir unloked | souheilh | Infinity-Box | 0 | 03-25-2009 13:47 |
Strange problem with infinity + pinfinder | sairat | Infinity-Box | 10 | 01-10-2009 18:29 |
succesfully unlock alcatel s210 with infinity+pinfinder | Haouas | Infinity-Box | 1 | 07-26-2008 20:33 |
