01-22-2010, 12:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Age: 43
Member: 232856 Status: Offline Thanks Meter: 69 | sfr 114 unlocked by infinity !!! :) COM4 [VCP1] selected module v3.01 Action: "sp-unlock" unlock method: smart fast Model: SFR-232 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3203:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: FES-FR-SFR-P103D1V1.0.1B01 Version: FES-FR-SFR-P103D1V1.0.1B01 44 byte(s) read imei: 358520030xxxxx connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to pyjaman For This Useful Post: |
01-22-2010, 20:54 | #2 (permalink) | |
Please, read full flash from SFR-114 like SFR-232 model and send full flash backup file (or link) to [email protected] Thank you ! | |
05-13-2010, 11:12 | #4 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 715445 Status: Offline Sonork: mire.centrino Thanks Meter: 45 | sfr 114 ok Model: SFR-114 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1003:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: FES-FR-SFR-P103D1V1.0.1B01 Version: FES-FR-SFR-P103D1V1.0.1B01 44 byte(s) read imei: 35852003080657 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 10 sec Remove/Install battery now |
The Following 2 Users Say Thank You to bleunuit For This Useful Post: |
12-19-2010, 17:16 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
06-11-2011, 09:06 | #7 (permalink) |
Insane Poster Join Date: Jun 2009
Member: 1064310 Status: Offline Sonork: 100.1680646 Thanks Meter: 26 | COM6 [VCP0] selected module v3.92 Action: "sp-unlock" unlock method: smart fast Model: SFR-114 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FC03:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: FES-FR-SFR-P103D1V1.0.1B01 Version: FES-FR-SFR-P103D1V1.0.1B01 44 byte(s) read imei: 35852003222870 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to zerda_all For This Useful Post: |
06-13-2011, 23:54 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
SFR 227 Unlock By Infinity | Chennairam | Infinity-Box | 1 | 11-23-2008 00:06 |
Cx70 v43 can i unlock with infinity :) | Moosani | Infinity-Box | 3 | 07-02-2005 11:57 |
bosch unlocker by cyberpreak :) | trafix | Various | 2 | 06-30-2001 15:41 |
SL45 unlock by imei :) | pascal77 | x1x to x45/x50 | 0 | 05-12-2001 02:02 |
