07-14-2008, 22:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | SFR 227 can not be unlock i have received one SFR 227 same as Vodafone 227, but this phone still lock after unlock it please check SFR 2217 can not be unlock COM7 [VCP0] selected Device: ZTE-227, Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sta_20080714-205756.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sec_20080714-205801.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-complete_20080714-205804.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 28 sec i unlock it as vodafone 227, but after this process the phone still lock i have already try to reset , but the phone still lock COM7 [VCP0] selected Device: ZTE-227, Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sta_20080714-210328.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sec_20080714-210331.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-complete_20080714-210334.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 22 sec please how can i unlock this phone thanks for advise regards leroi |
07-14-2008, 23:50 | #3 (permalink) |
Member: 107916 Status: Offline Thanks Meter: 30 | thanks for your prompt reply after finish unlock process and put sim in side in displayed : SIM LOCK but you can not type any thing, it seen that like the key pad did not work, but when you removed the unsupported sim card , the key works without problem. regards leroi |
★★Post here all unlocked HTC PHONES that can NOT be unlocked via HTC FACTORY CODES★★ | BaNgErS | PolarBox 3 | 0 | 01-13-2010 21:58 |
bf3 alcatel can not be unlock | gbada | VygisToolbox | 2 | 06-19-2005 03:38 |
Mpx200's can not be unlocked with 3.0 | BassGear | UniMoto | 0 | 01-28-2005 16:43 |
T100 can not be unlocked | dazexy | Sony Ericsson | 1 | 02-27-2004 18:23 |
3200 can not be unlocked!!!Guys this is not cable | silvester | Griffin | 11 | 12-15-2003 22:25 |
