01-20-2009, 13:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: tunisia tunis
Member: 640494 Status: Offline Sonork: 1583054 Thanks Meter: 67 | sfr 231 unlock problem plz help infinityteam but any connection with phone this is the log ----------------------------- COM18 [VCP0] selected module v2.60 Action: unlock unlock method: smart fast Model: SFR-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase #2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 8 sec Remove/Install battery now ! ---------------------------------- what is the problem and how can i solve it. |
01-20-2009, 16:33 | #2 (permalink) |
Member: 640494 Status: Offline Sonork: 1583054 Thanks Meter: 67 | sfr231 just unlocked COM18 [VCP0] selected module v2.60 Action: unlock unlock method: smart fast Model: SFR-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:A803:0009 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FR_SFR_P109B2V1.0.3B04 Version: 08JZTENJ25_07A_PMJ 44 byte(s) read imei: 35669002036734 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! le truc c HOLD Power button now |
The Following User Says Thank You to leader_gsm For This Useful Post: |
01-20-2009, 20:07 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-30-2009, 21:45 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | sfr231 unlock succeful COM6 [VCP0] selected module v2.61 Action: unlock unlock method: smart fast Model: SFR-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:0E03:0003 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FR_SFR_P109B2V1.0.3B04 Version: 08JZTENJ25_07A_PMJ 44 byte(s) read imei: 35669002023925 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 78 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to yahia ali For This Useful Post: |
03-15-2009, 22:52 | #5 (permalink) |
Freak Poster Join Date: Sep 2004
Member: 82815 Status: Offline Thanks Meter: 160 | SFR-231 is supported and thinks infinity-box SFR-231 is supported. COM2 [VCP0] selected module v2.67 Action: unlock unlock method: smart fast Model: SFR-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: boot initialization step #2 failed: 00 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:5703:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FR_SFR_P109B2V1.0.3B04 Version: 08JZTENJ25_07A_PMJ 44 byte(s) read imei: 35669002026714 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 247 sec Remove/Install battery now ! |
The Following User Says Thank You to princegsm For This Useful Post: |
03-17-2009, 14:39 | #6 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Pakistan Age: 46
Member: 438070 Status: Offline Thanks Meter: 7 | SFR-231 unlocked sucessfully COM3 [VCP0] selected module v2.67 Device: SFR-231 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:4C03:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P109B 2V1_0_3B04.BIN ver. sw 2: FR_SFR_P109B2V1.0.3B04, 00000000 ffs offset/size: 00B00000/00500000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P109B 2V1_0_3B04.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P109B 2V1_0_3B04.BIN]_20090317-183555.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ................... flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 0/1 ............................................. additional parameters detected Ok Special operation Done Write ... flash: EC257E25082501:2AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 423 sec Remove/Install battery now ! |
The Following User Says Thank You to Raja Com. For This Useful Post: |
!!x 70 unlocking problem plz help!! | rajabrotherscom | Infinity-Box | 7 | 08-03-2008 12:09 |
W810i unlock problem plz help !!! | A-H-T | Cruiser Suite | 7 | 03-01-2007 14:41 |
Panasonic VS2 unlock problem plz help | adi2002 | FuriousGold | 0 | 08-11-2006 22:40 |
V360v unlock problem,plz help! | gyuszko | Motorola P2K (USB-Smart) | 18 | 08-09-2006 06:04 |
Nec 343i unlock problem PLZ HELP!.. | MARKLOS | NEC | 2 | 06-20-2006 13:39 |
