Old 07-07-2009, 17:26   #1 (permalink)
Member: 411207
sfr 341 not unlocked with infinity???????
unlock standard
the log
COM5 [VCP0] selected
module v2.79
Device: SFR-341
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:E403:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22312200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.D5B6B 6A2.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z3_EFPSY_B0 7A105.BIN_4DCBBE45].rpl
identification#1 detection finished
device-id: D5B6B6A2
identification#1 protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z3_EFPSY_B0 7A105.BIN
ver. sw 2: X760_Z3_EFPSY_B07A105, BA4134B2
ffs offset/size: 00E00000/00200000
security area (code #1) check...
security area (code #1) fixed
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: SFR-341_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z3_EFPS Y_B07A105__ffs...
file saved: E:\Program Files\InfinityBox\MModule\SFR-341_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z3_EFPS Y_B07A105__ffs_20090707-182133.B0E.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation ...
detecting additional parameters...
Write: area 0/1
additional parameters detected Ok
error: additional parameters detection failed
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: E:\Program Files\InfinityBox\MModule\backup_security\SFR-341_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z3_EFPS Y_B07A105__system_log_D5B6B6A2_4DCBBE45_20090707-182355.B0X.bin
Finished, time used: 242 sec
Remove/Install battery now !
Old 07-07-2009, 17:29   #2 (permalink)
Member: 411207
with smard fast method
module v2.79
Action: unlock
unlock method: smart fast
Model: SFR-341
19200 autodetect
CPU: MT6225
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 75 sec
Old 07-07-2009, 17:31   #3 (permalink)
Member: 411207
i do compleete format same then unlok same problem
i flash eprom same
i flash full flach then unlok same problem
what a solution?????????????????
Old 07-07-2009, 17:37   #4 (permalink)
Member: 411207
it's a new hardware or what
Old 07-07-2009, 19:01   #5 (permalink)
yasermalik's Avatar
Member: 488632
have u tried any eeprom from support ??????
try to write nd post result
br
yasermalik
Old 07-08-2009, 08:53   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
module v2.79
Action: unlock
Model: SFR-341
19200 autodetect
CPU: MT6225
status: FF
Hello,
Try to press and HOLD phone "Power" button for more long time. It is need to hold "Power" button for this unlock method.
Old 07-08-2009, 09:02   #7 (permalink)
bootgsm's Avatar
Member: 527800
Originally Posted by InfinitySupport View Post
Hello,
I agree with you, just yesterday i had this problem with a new sfr341 so i choose standard fast method and keep power button pressed until the end after that phone was unlocked . smart fast methode wan't work for me all is ok but when i insert the sim card phone still locked .
again choose standard fast and keep power button pressed
Old 07-08-2009, 10:46   #8 (permalink)
Member: 411207
Phone is unlocked
i try 3 times with unlock standart
the soft give me the same error
then itry i put a sim surprise phone is unlocked ????????????????????????????????
Old 07-08-2009, 11:06   #9 (permalink)
Member: 130995
unlock standard
the log
module v2.79
Device: SFR-341
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: D5B6B6A2
Write: area 0/1
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Hello,
Software have tried to detect different lock types and one of them was fas found at first attempt so phone become unlocked.
Samsung C140 Not Unlock With Infinity anwar030 Infinity-Box 18 02-18-2010 10:19
huawai t156 bleu white not unlock with infinity santocon Infinity-Box 8 06-11-2009 09:12
w-377 not unlocked with infinity box vineet thapar Infinity-Box 2 05-30-2008 13:58
X70 can not unlock with infinity. KUBAT1 Infinity-Box 2 11-27-2007 10:16
spice s450 not unlock with infinity parveen kumar Infinity-Box 8 09-29-2007 14:03
Page generated in 0.31722 seconds with 11 queries
