03-28-2010, 03:50 | #3 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | sfr 342 full flash 100% ok sec setup imei number repiar ok module v3.28 Device: SFR-342 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware SFR-342_ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_ V2_Z0_C1_BFFA109_2009-07-30_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9203:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: 3E4661A3 rom info ver: 05 sw version: ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_V2_Z 0_C1_BFFA110.BIN project-id: X960_V2_Z0_C1_BFFA110, 18068B1F code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 9 min 4 sec Remove/Install battery now ! |
The Following User Says Thank You to shahid41 For This Useful Post: |
03-28-2010, 17:56 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @LABOSSEF Infinity-Box is a 100% complete solution for this kind of phones. Here is Infinity-Box support forum, so please, next time post your comments about other products in other forum section to avoid deleted messages again. |
sfr 342 readed as sfr 341 | f164 | Infinity-Box | 58 | 11-24-2009 23:10 |
Samsung GT-S8000, SFR 342, SFR 341, X760, X761 Unlocking with Z3X-BOX. | blang | Main Sales Section | 0 | 09-26-2009 07:31 |
ZTE GX760 · GX761 · SFR 232 · SFR 341 · SFR 342 · VAIRY · X760 · X761 Unlock by IMEI | UnlockBase.com | Main Sales Section | 0 | 09-26-2009 02:29 |
first sfr 342 unlocked in the world by code | the new | Easy-Unlocker | 0 | 09-25-2009 15:22 |
sfr 342 unlocked [Real First in The world] | the new | Z3X-Team Products | 0 | 09-25-2009 14:27 |
