SFR-342 unlocked 100 % tested with infinity-box First try change phone imei to 352962030027663, when insert other network sim carnd and enter this code ###825*09#, now you can enter unlock code: 604530028024. phone restarted and wola, phone 100 % unlocked and working. Next stpep change imei of your phone original.... I do job with MModule v2.94: Good luck. |
Hello, Please, read full flash from your unlocked phone and send full flash backup file to [email protected] Thank you ! |
big tks for all for this solution. Best Regards, JAVA Good. |
juste with v3 cable usb |
hi my brother sorry for my problems jijijijijj one bakup of alcatel unlocked working for trasformate to simfreee |
=== log: [11/24/2009 11:53:18 PM] ==== COM9 [VCP1] selected module v2.94 Device: SFR-342 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 8 sec Remove/Install battery now ! Imei 35296203008039 already was repaired: 11/24/2009-11:51:01 PM Continue with this imei ? Action: imei Model: SFR-342 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 352962030027663 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 352962030080399 verification Ok Finished, time used: 16 sec Power off phone now ! |
Great ! Small Time Hacker huh ! :D REGARDS!!! |
thenk you work 100% |
:D Quote:
u are smart just generate a code from ather imei and change imei yes correct..............:) thx brather |
aha good work my friend. thanks for crack solution :) |
thinks man so great frome ur side & great post u r genus:);) |
First in the world 1 Attachment(s) |
