12-28-2010, 19:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | sfr115 noir dead |
01-12-2011, 12:52 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: algeria
Member: 228703 Status: Offline Thanks Meter: 21 | this the log ==== [11/01/2011 16:28:29] ==== COM33 [VCP0] selected module v3.64 Action: "sp-unlock" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase #2/1 failed Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== [11/01/2011 16:28:47] ==== COM33 [VCP0] selected module v3.64 Action: "sp-unlock" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 28 sec Remove/Install battery now ! ==== [11/01/2011 16:29:41] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... ........................... lock area found ........................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 3 sec Remove/Install battery now ! ==== [11/01/2011 16:31:18] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [11/01/2011 16:33:56] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__fullflash_part_1_of_1... file saved: C:\Program Files\InfinityBox\MModule\SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__fullflash_part_1_of_1_20110111-164509.B0M.bin Finished, time used: 11 min 46 sec Remove/Install battery now ! ==== [11/01/2011 16:45:50] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110111-165125.B0E.bin Finished, time used: 5 min 45 sec Remove/Install battery now ! |
01-12-2011, 13:04 | #5 (permalink) |
Member: 228703 Status: Offline Thanks Meter: 21 | ==== [12/01/2011 11:43:01] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6012:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__firmware_part_1_of_1... file saved: C:\Program Files\InfinityBox\MModule\SFR115\SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__firmware_part_1_of_1_20110112-114915.B0M.bin Finished, time used: 7 min 50 sec Remove/Install battery now ! Loading file v.02... SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__fullflash_part_1_of_1_20110112-114248.B0M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-08-31 12-29 hw1: ZTENJ23D_09A_HW hw2: 09A_ZTENJ23D_09A Loading file v.02... SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110112-113057.B0E.bin loaded ==== [12/01/2011 11:53:50] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__fullflash_part_1_of_1_20110112-114248.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110112-113057.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:2AEA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 15 min 52 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [12/01/2011 12:15:01] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110112-122031.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 6 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [12/01/2011 12:23:18] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [12/01/2011 12:26:34] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [12/01/2011 12:29:08] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__fullflash_part_1_of_1_20110112-114248.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110112-113057.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:2AEA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 2 min 46 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [12/01/2011 12:34:49] ==== COM33 [VCP0] selected module v3.64 Action: "repair imei" imei write method: mode-2 new imei: 354030042836915 Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! Imei 35403004283691 already was repaired: 12/01/2011-12:35:13 Continue with this imei ? ==== [12/01/2011 12:35:15] ==== COM33 [VCP0] selected module v3.64 Action: "repair imei" imei write method: mode-2 new imei: 354030042836915 Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 42 sec Remove/Install battery now ! Imei 35403004283691 already was repaired: 12/01/2011-12:36:03 Continue with this imei ? ==== [12/01/2011 12:36:14] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 new imei: 354030042836915 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01__ffs_20110112-124139.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... 1 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 39 sec Remove/Install battery now ! ==== [12/01/2011 12:43:07] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-12-2011, 13:06 | #6 (permalink) |
Member: 228703 Status: Offline Thanks Meter: 21 | ==== [12/01/2011 12:47:18] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [12/01/2011 12:49:55] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 1 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== C:\Program Files\InfinityBox\MModule\MModule.exe [12/01/2011 12:58:16] ==== web site: Infinity-Box - About support forum in English: Infinity-Box - GSM-Forum Loading data, wait... [Infinity Box] MModule v3.64 smart-card: connected S/N: 3D48:0116 Wait... Device: Fly-E115 Done Device: SFR-115 Loading file v.05... SFR-115_ffs_02.B0E.bin loaded ==== [12/01/2011 12:59:32] ==== COM33 [VCP0] selected module v3.64 Device: SFR-115 Checking data, wait... advanced flash detection enabled Action: write flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs SFR-115_ffs_02.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6908:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.64, database date: 30.01.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B01.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: EC257E25082501:2AEA0000000000 Write: Eeprom/ffs Last edited by InfinityHelp; 06-27-2020 at 10:04. Reason: legacy links removed |
01-12-2011, 14:25 | #7 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | yo bro if you can find another 115 read full flash and use it to flash your phone but but first flash the phone do a full format and after that flash the phone i think your problem will be solve |
The Following User Says Thank You to GFTELECOM For This Useful Post: |
01-30-2011, 22:34 | #11 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | SFR 115 dead after unlock Quote:
please i have the same issue with 01 SFR 115 after unlock the phone cannot be powered on , i try to flash with flash file from support , phone still dead , please could you upload here the link where we can dowload the full flash read from another phone . thanks for your great support . @ support i think it is more safe to have the fullflash of this phone on support . regards, leroi | |
01-30-2011, 22:44 | #12 (permalink) | |
02-01-2011, 08:34 | #14 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | yo bro pm me in one hours and i will send you the full flash |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
