Old 10-04-2007, 07:27   #1 (permalink)
Member: 46019
Thanks Meter: 3
SiemensBenq EF51 can not write flash! help
COM3 selected
Device: BenQ EF51
Checking data, wait...
Action: Flash write
Skip: Firmware
Skip: Flex
Write: Language Pack
Skip: Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 001C:00C8001C00C8
flash: Mitsubishi B 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Err: error flash command
try#1 to recover write error at 01230000
Err: flash end
try#2 to recover write error at 01230000
Err: answer#20
try#3 to recover write error at 01230000
try#5 to recover write error at 0123E000
Err: answer#20
try#6 to recover write error at 0123E000
Writing Fail
Finished, time used: 37 sec
Remove/Install battery now !
READ flash ok
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
part 1 of 2...
Reading...
file saved: backup_full_part_1_of_2_20071004-121153.91X.bin
part 2 of 2...
Reading...
Help, thanks
Old 10-04-2007, 15:05   #2 (permalink)
Member: 148515
Thanks Meter: 14,729
hello!
full charge battery and use slower speed, like 115200
Old 10-04-2007, 15:21   #3 (permalink)
Member: 46019
Thanks Meter: 3
I will try , thanks
can not write flash please helppp!! KUBAT1 Infinity-Box 2 04-05-2008 11:48
EF51 can not be unlocked by last version M300_1_26SC tsarkh VygisToolbox 3 02-04-2008 09:37
Can not write flash in to MyX-5m Potvora SMTi 15 02-23-2007 10:07
X600 can not write flash djyash UST Pro II 6 03-28-2005 10:14
can not write flash up from 3D0000 adress misel Nokia Hardware & Hardware Repair 1 08-12-2002 14:09
Page generated in 0.22451 seconds with 8 queries
