-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   sigmatel fxd t66 pinout (http://forum.gsmhosting.com/vbb/f296/sigmatel-fxd-t66-pinout-908710/)
yuvrajkuber 01-23-2010 08:19
sir i have sigmatel fxd t66 .
this have mt6226a cpu wjth 6*2 connector .
i need pinout for this mobile...
InfinityHelp 01-23-2010 11:27
hello!
and connector type is.... ?
yuvrajkuber 01-24-2010 05:56
Sir thanks for support
BUT CONNECTOR IS 6x2 CONNECTOR
InfinityHelp 01-25-2010 19:30
hello!
if you dont have pinfinder i can teach you how to test pins by multimeter.
very easy procedure for searching pinout on MT62xx MCU based phones
cellexpert 01-27-2010 19:19
r x
t g
x g
r 4 rx , t 4 tx ,x 4 noting, g 4 ground ,check ground vaya multimeter and see my word in jumetry..............................
gsmsikar 01-27-2010 20:24
i also have a hxd t66 set which is having wt6226a CPU , can anyone give the pinout of that set ?
ravipal_82 05-02-2010 10:51
the conneter is like v3 plz help
InfinityHelp 05-02-2010 19:22
hello!
If you dont have infinity Pinfinder- i can teach how to find pinout in minutes.
Just by measuring voltage on phone system connector pins.
teknisi bloon 05-03-2010 05:26
Originally Posted by InfinityHelp (Post 5789270)
hello!
i would like to learn how to find pinout manually :D
InfinityHelp 05-03-2010 18:13
hello!
1. set multimeter to voltage measuring.
2. power Onphone
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone must be powered On)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
gsmsikar 05-04-2010 07:26
Originally Posted by InfinityHelp (Post 5792955)
hello!
2. power Onphone
those are tx/rx
what is the meaning of this line ? i didnt understand
InfinityHelp 05-04-2010 20:45
hello!
use needle to touch connector pins.
it is very thin, so you will get better results
alim3899 06-04-2010 12:43
WT 6226A Cpu in Sigmatel HXD- T66. Any one give me WT 6226A IMEI changer
Page generated in 0.35803 seconds with 5 queries
