Old 01-23-2010, 09:19   #1 (permalink)
Registered User
Member: 1213999
Thanks Meter: 4
sigmatel fxd t66 pinout
sir i have sigmatel fxd t66 .
this have mt6226a cpu wjth 6*2 connector .
i need pinout for this mobile...
Old 01-23-2010, 12:27   #2 (permalink)
Member: 148515
Thanks Meter: 15,713
hello!
and connector type is.... ?
Old 01-24-2010, 06:56   #3 (permalink)
Registered User
Member: 1213999
Thanks Meter: 4
Sir thanks for support
BUT CONNECTOR IS 6x2 CONNECTOR
Old 01-25-2010, 20:30   #4 (permalink)
Member: 148515
hello!
if you dont have pinfinder i can teach you how to test pins by multimeter.
very easy procedure for searching pinout on MT62xx MCU based phones
Old 01-27-2010, 20:19   #5 (permalink)
cellexpert's Avatar
Member: 857876
Sonork: cellexpert-33
Thanks Meter: 63
r x
t g
x g
r 4 rx , t 4 tx ,x 4 noting, g 4 ground ,check ground vaya multimeter and see my word in jumetry..............................
The Following User Says Thank You to cellexpert For This Useful Post:
Old 01-27-2010, 21:24   #6 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 768
i also have a hxd t66 set which is having wt6226a CPU , can anyone give the pinout of that set ?
Old 05-02-2010, 11:51   #7 (permalink)
ravipal_82's Avatar
Member: 1194176
Thanks Meter: 203
the conneter is like v3 plz help
Old 05-02-2010, 20:22   #8 (permalink)
Member: 148515
hello!
If you dont have infinity Pinfinder- i can teach how to find pinout in minutes.
Just by measuring voltage on phone system connector pins.
Old 05-03-2010, 06:26   #9 (permalink)
Member: 624177
Thanks Meter: 23
hello!
i would like to learn how to find pinout manually
Old 05-03-2010, 19:13   #10 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. power Onphone
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone must be powered On)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 05-04-2010, 08:26   #11 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 768
hello!
2. power Onphone
those are tx/rx
what is the meaning of this line ? i didnt understand
Old 05-04-2010, 21:45   #12 (permalink)
Member: 148515
hello!
use needle to touch connector pins.
it is very thin, so you will get better results
Old 06-04-2010, 13:43   #13 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
WT 6226A Cpu in Sigmatel HXD- T66. Any one give me WT 6226A IMEI changer
need pinout sigmatel fxd 3600 bassemzini Infinity-Box 0 03-29-2010 20:22
sigmatel fxd s9000 pinout need ashok_kumar459 Infinity-Box 2 02-20-2010 17:46
sigmatel fxd t99i pinouts jack81 Infinity-Box 0 09-18-2009 11:46
need sigmatel fxd T33i flash file. shuaib_kashish Infinity-Box 10 09-12-2009 06:04
sigmatel fxd s90 plz help shakir hashmi Infinity-Box 3 04-08-2009 19:29
Page generated in 0.40460 seconds with 8 queries
