Sigmatel FXD6100 Usercode Hello I`ve sigmatel FXD6100 with unknown usercode. Fw is not supported (but already sent to support). Is there any other chance to get Usercode/Reset it? Or do I have to wait for Update... |
Not possible........ |
hello! did you try to make format FFS complete? |
No... ithought I`d delete files on the phone. or is that wrong? |
Formating FFS worked... but now I get "unlawful" on startup? What does this means? |
hello! i have no idea... |
I already sent Flash to your support... but no one seems to be interested? :) I tried formatting FFS as I told... but formating FFS also deletes IMEIs.... the same happens if I flash other Firmware... even though Usercode is set to "1122" again with new/old FW... is there any chance you support new FW... or can I download "FFS-Content" and search for usercode (Ifinity-readouts are crypted...) ? |
hello! which format method did you try? safe or complete? |
Both... even manual Format (where you can selebct Items to be deleted...). I tried even other FW from support... |
* *983*7469# version * *983*1688# batterie temperature * *983*5391# keypad test * *983*5651# phone reset and user code reset also * *983*757# sim lock info * *983*22387# master reset * *983*2831# audio test __________________try with this code.i think it will work......... |
I cant enter codes... only Phonecode... _:( |
hello! please show format FFS complete log. maybe this phone has double CPU and you work with second (slave) one |
COM3 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2603:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: FXD-6100_01_V1.0.018_090421 Version: PCBAV2.1 detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35350303024878 connection Ok building list... done items to clear: 141 warning: wrong packet cs warning: wrong packet cs items cleared: 141 of 141 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! Here is log of FFS (Safe mode) |
hello! i still insist on posting "Complete" format Log, not "safe" |
COM7 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2603:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: c:\Programme\InfinityBox\ChineseMiracle\backup_sec urity\id.3A10690F.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_233E403E].rpl ==================== New firmware found (v.3.26, database date: 13.01.2011): GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 3A10690F rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN project-id: FXD-6100_01_V1.0.018_090421, 3E403E23 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421__ffs... file saved: C:\Programme\InfinityBox\ChineseMiracle\GINWAVE25_ 08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421__ffs_20110216-095829.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: c:\Programme\InfinityBox\ChineseMiracle\backup_sec urity\GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.F XD-6100_01_V1_0_018_090421__system_log_3A10690F_233E4 03E_20110216-095850.B0X.bin Finished, time used: 4 min 50 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Here we go :) |
