Old 02-07-2011, 12:34   #1 (permalink)
Member: 76018
Thanks Meter: 59
Sigmatel FXD6100 Usercode
Hello
I`ve sigmatel FXD6100 with unknown usercode. Fw is not supported (but already sent to support).
Is there any other chance to get Usercode/Reset it? Or do I have to wait for Update...
Old 02-07-2011, 14:58   #2 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
Not possible........
Old 02-07-2011, 20:39   #3 (permalink)
Member: 148515
Thanks Meter: 14,733
hello!
did you try to make format FFS complete?
Old 02-07-2011, 21:55   #4 (permalink)
Member: 76018
Thanks Meter: 59
No... ithought I`d delete files on the phone. or is that wrong?
Old 02-08-2011, 19:11   #5 (permalink)
Member: 76018
Thanks Meter: 59
Formating FFS worked... but now I get "unlawful" on startup? What does this means?
Old 02-08-2011, 20:49   #6 (permalink)
Member: 148515
hello!
i have no idea...
Old 02-09-2011, 14:56   #7 (permalink)
Member: 76018
Thanks Meter: 59
I already sent Flash to your support... but no one seems to be interested?
I tried formatting FFS as I told... but formating FFS also deletes IMEIs.... the same happens if I flash other Firmware... even though Usercode is set to "1122" again with new/old FW... is there any chance you support new FW... or can I download "FFS-Content" and search for usercode (Ifinity-readouts are crypted...) ?
Old 02-09-2011, 20:10   #8 (permalink)
Member: 148515
hello!
which format method did you try?
safe or complete?
Old 02-09-2011, 20:43   #9 (permalink)
Member: 76018
Thanks Meter: 59
Both... even manual Format (where you can selebct Items to be deleted...).
I tried even other FW from support...
Old 02-10-2011, 16:10   #10 (permalink)
Member: 462514
Sonork: 100.1596836
Thanks Meter: 602
* *983*7469# version
* *983*1688# batterie temperature
* *983*5391# keypad test
* *983*5651# phone reset and user code reset also
* *983*757# sim lock info
* *983*22387# master reset
* *983*2831# audio test
__________________try with this code.i think it will work.........
Old 02-10-2011, 19:42   #11 (permalink)
Member: 76018
Thanks Meter: 59
I cant enter codes... only Phonecode... _
Old 02-10-2011, 20:28   #12 (permalink)
Member: 148515
hello!
please show format FFS complete log.
maybe this phone has double CPU and you work with second (slave) one
Old 02-12-2011, 16:14   #13 (permalink)
Member: 76018
Thanks Meter: 59
COM3 [VCP0] selected
module v3.26
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2603:0009
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: FXD-6100_01_V1.0.018_090421
Version: PCBAV2.1
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35350303024878
connection Ok
building list...
done
items to clear: 141
warning: wrong packet cs
items cleared: 141 of 141
building list...
done
items remains: 0
Finished, time used: 27 sec
Remove/Install battery now !
Here is log of FFS (Safe mode)
Old 02-13-2011, 18:47   #14 (permalink)
Member: 148515
hello!
i still insist on posting "Complete" format Log, not "safe"
Old 02-16-2011, 21:49   #15 (permalink)
Member: 76018
Thanks Meter: 59
COM7 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: c:\Programme\InfinityBox\ChineseMiracle\backup_sec urity\id.3A10690F.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_233E403E].rpl
New firmware found (v.3.26, database date: 13.01.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 3A10690F
rom info ver: 05
sw version: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN
project-id: FXD-6100_01_V1.0.018_090421, 3E403E23
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421__ffs...
file saved: C:\Programme\InfinityBox\ChineseMiracle\GINWAVE25_ 08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421__ffs_20110216-095829.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: c:\Programme\InfinityBox\ChineseMiracle\backup_sec urity\GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.F XD-6100_01_V1_0_018_090421__system_log_3A10690F_233E4 03E_20110216-095850.B0X.bin
Finished, time used: 4 min 50 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Here we go
Siemens C25 UserCode? kostin x1x to x45/x50 3 02-19-2002 22:28
mc930 usercode problem bojans Infineon C16X M51 & ARM7 M52 BASED 1 10-31-2001 10:22
How to unlock usercode Siemens S35 v18 ?? sp-lox x1x to x45/x50 1 10-11-2001 07:34
Tool for usercode? Blu3fish Alcatel & TCL Old Models 3 01-14-2001 21:18
usercode on siemensc25 mobileinfo x1x to x45/x50 0 05-24-1999 01:17
Page generated in 0.43006 seconds with 8 queries
