Old 01-07-2010, 17:23   #1 (permalink)
Member: 1086393
Thanks Meter: 771
sigmatel Lxd 7600 dead
Hi, i just flash this phone with same model phone file and its dead now, when i restore its original file- files goes smootly on the phone but did'nt power on. At first the problem of the phone is-- hang on logo.
Here is the detail of the file:
HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_AL X_S33_18_ML_A_1_V02.BIN
if any body hv this file pls share,, i did'nt found on the support.
I did complete ffs, Repair security area etcc, but same(dead_)
Old 01-07-2010, 22:07   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try this one:flashfiles/ChineseMiracle/_MT6225/HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_AL X_S33_18_ML_A_1_V03_16m_En_Ru_Gr_Fr_Es_Id_Vn_Tr_Fa rsi_Pt_Ar.B0M.bin
Old 01-08-2010, 06:31   #3 (permalink)
Member: 1086393
Thanks Meter: 771
yes i did but did'nt power on-- any other way to solve
COM10 [VCP1] selected
module v3.05
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:CB03:000A
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.05, database date: 30.12.2009):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37C_AL X_S33_18_ML_A_1_V02.BIN
project-id: 6302_C37C_ALX_S33_18_ML_A_1_v02, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 9 min 1 sec
Remove/Install battery now !
The Following User Says Thank You to Riteshgpt60 For This Useful Post:
Old 01-09-2010, 20:26   #4 (permalink)
Member: 148515
hello!
well, in this case only same firmware can help.
you must look for same working phone or flash file (even in BIN format)
Sigmatel lxd s36 FaHaD_DePaR Chinese Models & Cloned Phones 0 03-12-2010 10:43
need flash file sigmatel lxd 7600 >>PakFones<< Chinese Models & Cloned Phones 3 10-12-2009 05:35
7600 dead Marlon Lewis Nokia Digital Core Technology 4 ( DCT-4 ) 6 03-21-2005 09:06
Page generated in 0.14875 seconds with 9 queries
