10-07-2009, 18:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Sigmatel restart with sim after ffs etc. It works fine without SIM. It restart usually when receiving call, when phone in standby mode it did'nt restart. I'm confused with this problem. INFINITY TEAM is the only solution |
04-11-2010, 10:37 | #6 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | i m facing same problem, s4 with out sim working fine 112 call ok , but with sim when i try to pwer on, it power off with in sec, some time it power on but when try to call or recving call it switch off. after imei rebuld after 5/10 menut its imei agan goes to 13556569585555 (invalid sim ) again i ffs then rebuld imei but again after 5/10 menit its imei goes to 135265656666 . plz help |
04-11-2010, 11:07 | #7 (permalink) | |
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
Use search Option-- Already posted many Times | |
04-11-2010, 12:45 | #9 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | it is working with out sim (112 call is also working) it is working with dfalt imei (1356*********) after writing good imei, it power off with in sec with sim after 5/6 hour it again become dead. then again complete ffs, again same......................... |
04-12-2010, 14:35 | #11 (permalink) | |
Member: 367928 Status: Offline Thanks Meter: 178 | Quote:
Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ...................... detect standard ffs/eeprom location pass #1... .................................................. ... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:18E59F00000000 flash: 01227E22202200:18E59F00000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 6 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! still same after startup tone mobile power off, with sim, with out sim it is working , i already chage batry | |
04-13-2010, 20:02 | #14 (permalink) | |
i try with diffrent flesh files but canot power on, BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_NO TP_EFIAPVRHMIT_V042__fullflash_20100413-175029.B0M (read from another working same S4 fone) KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12_16m_En_Ru_Fr_Es_De_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0M ( from support) MT6225/eeprom/KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12__ffs_01.B0E.bin ( from support) but mobile cannot power on after flesh wth these files. | |
cect v180 restarting problem but after ffs same problem | shripalkawdia | Infinity-Box | 9 | 05-09-2009 02:06 |
G600 restarts with sim after unlock : WHYYY ? | zeel_zeel | NSPRO | 1 | 03-21-2008 02:28 |
after also format ffs phone restart with sim | EMOTION BBSR | Infinity-Box | 5 | 02-17-2008 13:25 |
How to reapair restart with sim card, N95 with 2 sim? | .:RAGE:. | Infinity-Box | 13 | 11-30-2007 14:56 |
w900 after flashing restart with sim | iyass | Cruiser Suite | 6 | 10-09-2007 18:54 |
