07-16-2008, 11:50 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Sigmatel S1 Still Dead?????????? COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:6203:0001 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:18A59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080716-124234.B0E.bin flash: EC257E25082501:18A59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18A59F00000000 Finalization Done Finished, time used: 139 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! IFLASH THE PHONE THIS VIRSION:- GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226_Sigmatel-S1_En_Fr_Vn_Ru_Ar_Th.B0M.bin AND MY BACKUP FULLFLASH IS:-flash_20080716-120203.B0M PLESE HELF. |
07-16-2008, 12:29 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | Quote:
br mobilecraker | |
07-16-2008, 15:49 | #4 (permalink) | |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226_Sigmatel-S1_En_Fr_Vn_Ru_Ar_Th.B0M.bin can anather idea plese tell. | |
07-16-2008, 15:52 | #5 (permalink) | |
at this email:[email protected] | |
07-16-2008, 16:19 | #6 (permalink) |
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | the flash file you is ok n fine for this mobile,resold flash ,cpu n surrounding components with flex n hot air station |
07-16-2008, 16:19 | #7 (permalink) |
Freak Poster Join Date: Dec 2006 Location: INDIA
Member: 416940 Status: Offline Thanks Meter: 173 | i also having same problem flashing is ok but phone is not getting on then i disassemble the phone and given slight hit on the ic. problem is solve .just try ur luck bro......... |
07-16-2008, 22:25 | #10 (permalink) | |
this is phone sir- | |
07-17-2008, 10:16 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! send me eeprom backup to [email protected] i will look inside maybe will find what version it was |
07-17-2008, 15:34 | #13 (permalink) | |
07-18-2008, 11:46 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i asked you to send me eeprom backup "eeprom_20080716-124234.B0E.bin" but you sent me full flash. please find mentioned above eeprom backup and send it to me |
sigmatel s1 dead plz help | subra007 | Infinity-Box | 4 | 03-09-2009 12:32 |
sigmatel s1 dead after flash | bhogpurmail | Infinity-Box | 18 | 09-22-2008 18:40 |
sigmatel s1 dead by format | jitugrover | SpiderMan | 5 | 09-21-2008 14:34 |
sigmatel s1 dead | jitugrover | Chinese Models & Cloned Phones | 2 | 08-08-2008 12:24 |
sigmatel s1 file not found at support area | SAHEB | Infinity-Box | 1 | 05-26-2008 17:55 |
