10-09-2008, 10:57 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Try these points one by one with some Pin Finder. For example SpiderMan,PAD Finder or Infinity Pin Finder. I am sure that some secret is hidden within these poinits. BEST OF LUCK yawarniazi |
10-10-2008, 16:33 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: there Age: 19
Member: 77394 Status: Offline Thanks Meter: 118 | OK lets see if i follewed this guide: http:///vbb/showthread.php?t=433447 can i use immidiately the pcb gnd as gnd / or use the batterie (-) pin as gnd. and jump to step2. in step: 2 may i powered the pcb by power suply ? power on the phone or not ? thanks in advance |
10-10-2008, 17:57 | #8 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Barcelona
Member: 206476 Status: Offline Thanks Meter: 459 | @wolf dz u can use multimeter seek for 2.74 v on this test point that's all u must find tow point tike 2.74 v one rx and second tx gnd any place - on pcb wbr |
The Following User Says Thank You to freeman2001 For This Useful Post: |
10-10-2008, 18:05 | #9 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi all.. u r sure that phone hasnt spreatrum cpu..? i cant read the chracters on the cpu...it loooks like spreadtrum cpu...cause of one cpu and 2 imei.. but maybe..maybe it can be mtk too... b.r.. |
The Following User Says Thank You to LoveLess For This Useful Post: |
10-10-2008, 21:00 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please let us know your CPU type. also: using power supply for pinout detection will give incorrect voltage values. so please use good charged battery instead |
10-10-2008, 21:13 | #11 (permalink) |
Member: 77394 Status: Offline Thanks Meter: 118 | thanks to Freeman and loveless and InfinityHelp cpu: SPREADTRUM- sc660QD5-180G q? may i need to power on the phone or can do the operation with off phone. |
10-10-2008, 22:23 | #14 (permalink) |
Member: 206476 Status: Offline Thanks Meter: 459 | just u need his original usb cable power the phone without sim pc detcte new hw install his driver and read documontaion on C:\Program Files\InfinityBox\SPD2\UserManual wbr |
Cect U90 18 pin connector pinout here | techie786 | Infinity-Box | 1 | 02-03-2009 17:53 |
hi i need pinout for 6300 (7 pins) | faisal butt | J.A.F. By Jafsupport.com | 8 | 12-16-2008 12:16 |
Need Samsung full 18 pins connector for NEC phone. | LarryA | NEC | 1 | 08-10-2008 06:53 |
Pinout For Nokia N95 2 Sim 18 pin connector | MarvelXZ | Infinity-Box | 1 | 02-26-2008 00:31 |
N95s dual sim 18 pin connector pinout | .::Zafar Communication::. | Infinity-Box | 2 | 06-12-2007 20:34 |
