Old 10-07-2008, 18:18   #1 (permalink)
rajendrakumar's Avatar
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
need s2 headphone symbol soln
hello sir,
i have sigmatel s2 phone.the phone is in head phone symbol.i clean the jack and heat the jack.i also change the mic.but still same.i put the phone in infinity.it shows flash error.the flash file is totally damaged. so please any one please upload the head phone symbol solution and s2 working phone flash file.
thanks in advance.
Old 10-07-2008, 21:14   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post what flash error do you face.
maybe this will bring light to your problem
Old 10-09-2008, 16:35   #3 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
hello sir,
i put the phone in infinity box.i give test point rx tx.gnd.when i select format safe,
COM3 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:3C03:0009
Connecting, wait...
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs
19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support
connection lost
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
then i select format complete,in 92600 baudrate
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
boot step size: 0400
Boot Done
Initialize...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
error: wrong answer: C3
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 11 sec
then i select 115200
Action: repair security area
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1_0_013_080306.BIN
ver. sw2: FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1.0.013_080306, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
Finalization Done
Finished, time used: 19 sec
then i rebuild imei.
now the phone goes to touch screen calibration mode.the touchscreen did not work now.
then i press repair security area
it also running correctly
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6225, E03
Hardware version: GINWAVE25_06B_HW
Software version: FXD-S3_FOREIGN_MR106
Software date: 2006.06.14
Barcode: AT+EGMR=0,5
imei: 135790246811220
imei write method: mode-1
new imei: 357569000134562
imei verified Ok
Finished, time used: 8 sec
Power off phone now !
now the phone is in touchscreen calibration mode.but the calibration symbol not shown
the detected eeprom is
below attached
backup_eeprom[GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1_0_013_080306.BIN]_20081009-202524.B0E
isany sol please reveal soon
Old 10-09-2008, 17:00   #4 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
hello sir,
i have infinity box with pinfinder..i installed the latest update pinfinder 1.14.when i select the pinfinder in my pc.there is a error message shows please update ur dongle manager.then i go to suppport site and download and install the latest dongle manager.but still same problem.then i reinstal the ver 1.10 .the version work very well.is any soln please reveal soon.
the other problem is i install the latest chinese miracle exe.2.60.when i try to open in the cell it also reveal please update the dongle manager.then i install the before version it works o.k.
Old 10-09-2008, 19:42   #5 (permalink)
Cryspim's Avatar
Member: 62561
Thanks Meter: 706
Originally Posted by rajendrakumar View Post
hello sir,
Did you perform Dongle Upgrade process correctly? Follow this steps:
As you can see, you can start Chinese Miracle Module (v2.63) without problems after this.
B.r.
cryspim
The Following 2 Users Say Thank You to Cryspim For This Useful Post:
Old 10-09-2008, 22:51   #6 (permalink)
Member: 148515
hello rajendrakumar!
Please use "touchscreen calibration bypass" to skip "calibation" procedure.
and make dongle upgrade as described in "Cryspim" post
Old 10-10-2008, 08:06   #7 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
hello sir,
i cant able to download the latest chinese miracle update 2.63.only 70% will download in the support site. in the support site.
Old 10-10-2008, 14:05   #8 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
hello sir,
i succesfully upgrade my dongle and successfully installed the latest versions.thank u crispm.
Old 10-10-2008, 20:32   #9 (permalink)
Member: 148515
hello sir,
hello!
please select different support site mirror
find one with best speed
Old 10-11-2008, 07:25   #10 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
thank you very much sir,
please reveal the sigmatel s2 head phone symbol solution.
thanks in advance.
Old 10-11-2008, 13:35   #11 (permalink)
Member: 148515
thanks in advance.
hello!
make full backup
start from formating FFS, if will not help- make flashing by suitable firmware.
if still not luck- turn to hardware check
j100i headphone symbol anbu_selvaan Sony Ericsson Hardware Repair 14 05-14-2011 16:54
cect v180 headphone symbol jobykjoseph Chinese Models & Cloned Phones 0 05-21-2008 09:52
w660 headphone symbol appear Turks Sony Ericsson Hardware Repair 0 03-04-2008 07:54
3220 headphone symbol.... ..:MumbaiGsm:.. Nokia Hardware & Hardware Repair 4 08-20-2007 10:38
nokia 6101 headphone symbol Johnessen Nokia Hardware & Hardware Repair 1 08-24-2006 06:25
Page generated in 0.21489 seconds with 9 queries
