12-27-2008, 17:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 205128 Status: Offline Thanks Meter: 18 | new firmware t156 COM11 selected module v1.57 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20081227-165915.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20081227-165915.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081227-165928.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20081227-165933.B1E.bin backup critical area Done Check memory ... error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 32 sec Remove/Install battery now ! |
12-27-2008, 17:54 | #2 (permalink) | |
You can see a solution in your own message. | |
12-27-2008, 19:50 | #3 (permalink) |
Member: 205128 Status: Offline Thanks Meter: 18 | solved!!! update to v1.58 thanks COM11 selected module v1.58 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20081227-194658.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20081227-194659.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081227-194704.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20081227-194709.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! |
The Following User Says Thank You to GAZZUZZ For This Useful Post: |
Need unlock code for VDF136 new firmware here is dump. | azeem781986 | FuriousGold | 16 | 05-26-2010 04:48 |
New HUAWEI T156 Erorr with conecting by vgis box | hussainafridi | VygisToolbox | 3 | 05-01-2010 14:38 |
New Ufone T156 Unlock Done | ZubairArain | Infinity-Box | 5 | 12-14-2009 07:13 |
FuriousGold added NEW HUAWEI T156 NEW SECURITY - FREE UPDATE - V1.0.0.3123 | FuriouS TeaM | Service Products News & Updates | 0 | 11-12-2009 20:04 |
cannot remove sp lock of new huwai T156 (ufone) | malik m. salim | Infinity-Box | 4 | 11-06-2009 15:10 |
