09-10-2008, 15:34 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | sigmatel s4 & iphone sigmatel s4 and iphone read full flash eeprom ok, complete ffs format ok , but no power on , I flash mobiles and repair secruity area no use. any solution please........ |
09-10-2008, 16:33 | #2 (permalink) |
Member: 76882 Status: Offline Thanks Meter: 56 | sir please check logs: 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_ET FIHAP_V026.BIN ver. sw2: S4_TOSHIBA_ETFIHAP_V026, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:18E59F00000000 Finalization Done Finished, time used: 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-10-2008, 20:35 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | dear do complete format with charged battery after done press power botton for one minute or resold flash IC will b 100% on good luck |
Flight Mode to Dual Sim Mode in Sigmatel S4? | priyoghosh | Chinese Models & Cloned Phones | 82 | 09-16-2013 12:23 |
Camera and video recoder problem in SIGMATEL S4 chinees Mobile | sandipdas365 | Chinese Models & Cloned Phones | 4 | 06-20-2009 09:58 |
Sigmatel S4 | xpsunny | Infinity-Box | 10 | 08-21-2008 22:25 |
How to use Net through Sigmatel S4 ? | misrmp | Chinese Models & Cloned Phones | 1 | 08-20-2008 08:13 |
Sigmatel S4 | xpsunny | Chinese Models & Cloned Phones | 2 | 08-18-2008 10:46 |
