Old 10-04-2010, 16:08   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 641
sigmatel s88 need flash file
T600_v05_pcb01_gprs_mt6226_s01.t600_v05_enfrarrusp pevi_sigmatel.bin
Old 10-04-2010, 19:07   #2 (permalink)
Member: 148515
Thanks Meter: 15,716
hello!
what is wrong with your phone? have you tried to solve this withut flashing, just by format FFS/IMEI restore? Leave flashing to last thing to do.
here is available on support flash files:
flashfiles/ChineseMiracle/_MT6226/T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__S88_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M .bin
flashfiles/ChineseMiracle/_MT6226/T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S90i_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S98_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M.bin
Old 10-05-2010, 08:18   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 641
hello!
COM3 [VCP0] selected
module v3.23
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 357263028882697
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 00315A4:2305
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN
project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00500000
Detected ffs/eeprom address is non-standard: 00500000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00500000
detecting ffs/eeprom size...
ffs/eeprom size: 00B00000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00500000-00FFFFFF
firmware area: 00000000-004FFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: can't detect record name location
error: ffs/eeprom detection failed element #2
error: can not detect default imei value
Patch required data Fail
Finished, time used: 1 min 16 sec
Remove/Install battery now !
still mobile is working but when i try to power on that mobile it was show not calliberate on that display now
so pls help this problem
Old 10-05-2010, 19:06   #4 (permalink)
Member: 148515
hello!
you did not answer my questions.
what was initial phone problem?
have you tried to solve it without flashing?
finally: do calibration by taping test points.
Old 10-06-2010, 06:47   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 641
hello!
hi information below
customer gave to imei changing purpose but i have another same model. condition was dead but i was try all version but it was not getting power on.lastly i did get full flash back up from imei set after backup.i forget to write into dead set that imei backup flash file. wrongly i did flash into imei set so after completed set was not poweron . then i asked that i need flash file
this is my problem
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 17:24
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware Repair 2 07-23-2013 03:41
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 12:35
Page generated in 0.30135 seconds with 8 queries
