07-28-2009, 10:44 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | Sigmatel s88 not calibrated solution |
The Following 4 Users Say Thank You to tajinder For This Useful Post: |
07-29-2009, 22:31 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to calibrate touchscreen (if toucscreen panel is damaged): 1. connect cable from box to phone 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
08-06-2009, 23:25 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258 Please, try to calibrate phone with new software, waiting for your results. |
08-07-2009, 08:56 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Yes Try with latest update as i did n got success logs posted in forum with new procedure LONG_LIVE INFINITY,, BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
08-09-2009, 16:54 | #6 (permalink) |
Member: 214340 Status: Offline Thanks Meter: 906 | ANOTHER_TOUCH_SCREEN_CALIBRATION_DONE_WITH_NEW_UPD ATE LOGS COM12 [VCP0] selected module v2.87 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... M200DS_PCBV1_1_GPRS_MT6226_S01.M200DS_CE_127N_O70_ BT_V04__fullflash_20090809-083643.B0M.bin loaded detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:803E:E551 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M200DS_CE_127N_O70_BT_V04 Version: FYD26_05C_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 204 byte(s) read reading data #2... writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! LONG_LIVE_INFINITY BR |
The Following 2 Users Say Thank You to mobile_hotman For This Useful Post: |
10-05-2009, 07:48 | #7 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 360614 Status: Offline Thanks Meter: 63 | Any possible idea with spiderman, cause I don't have infinity. Or can u give me a link of flash file of sigmatel S98 MTK_ROMINFO_v04T600_V05_PCB01_GPRS_MT6226_S01.T600 _V05_ENFRARRUSPPEVI_SIGMATEL.BIN |
sigmatel S88 shows NOT CALIBRATED | k_abhi | Infinity-Box | 27 | 12-13-2011 11:17 |
China Sigmatel S88 when swithc on says " Not calibrated" | mukeshdurg | Chinese Models & Cloned Phones | 14 | 11-10-2010 01:30 |
Frome F8 Not Calibrate solution | babloojaved | Infinity-Box | 0 | 02-08-2010 11:45 |
china s88 shows - NOT CALIBRATED | k_abhi | SpiderMan | 1 | 01-01-2010 14:44 |
sigmatel s88 shows only not calibrate | rakesh15 | Infinity-Box | 0 | 06-11-2009 06:51 |
