sigmatel s90 i have one sigmatel s90, the problem is cant able to make a call first i backup flash by using spiderman and then fromet with infinity in that process the problem is not able to solved. and then i fromet whole flash chip with infinity and the phone is dead and then i flash again with my backup file the phone is not able to on please help need solution |
sigmatel s90 Quote:
HELLO , MY DEAR FORUM MEMBER . ITS YOUR MISTAKE BECAUSE THERE IS TWO BOX FIRST =SPIDERMAN. SECOND= INFINITY SO LET ME CLEAR YOU THAT THOSE BOX HAS USING TWO TYPE OF FILE SPIDERMAN HAS 16MB INFINITY HAS BETWEEN 8-16 MB FILE So As YOU mention here that i backup flash by using spiderman and then fromet with infinity in that process the problem is not able to solved. and then i fromet whole flash chip with infinity and the phone is dead and then i flash again with my backup file. so now you again format with the help of infinity box. So as I mention here that there is two types of file using . so now you have to full flash your phone by the help of infinity box and use infinity flash file. thanks!!!!!!!!!!!!!! |
hello! please pay attention to IMEI in your phone. it should be set to valid value. you can see it by pressing *#06#. |
sir my phone is dead now, so now you again format with the help of infinity box. So as I mention here that there is two types of file using . so now you have to full flash your phone by the help of infinity box and use infinity flash file. thanks!!!!!!!!!!!!!! Report Post Reply With Quote or please give me flash file |
hello! restore backup and fix IMEI |
