10-09-2008, 06:37 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | n95 With PIN code it HANG without PIN ok! Can i used another version of flash file? Please guide. OM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031711:E56A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.06B.W07.04.MP.V32 Version: N95_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35307901120235 connection Ok building list... done items to clear: 181 warning: wrong packet cs 167 of 181 items cleared building list... done 0 items remains Finished, time used: 97 sec Remove/Install battery now ! |
10-09-2008, 20:39 | #3 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
But SAME after tried to flash with another FIRMWARE the phone is ON but the DISPLAY is very bad .. and it does not stuck on CODE ACCEPTED Anymore!! How to identify the right FIRMWARE to use on such mobiles... !!! | |
10-09-2008, 22:53 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! First of all you must make "read detailed information" and then pick correct flash file. here is step-by-step tutorial how to make this: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
10-10-2008, 07:14 | #5 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031711:E56A high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9FF4AE26.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_B66274F4].rpl identification#1 detection finished device-id: 9FF4AE26 identification#1 protocol ver: 04 ver. sw1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN ver. sw2: MAUI.06B.W07.04.MP.V32, 0B8B9D49 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9FF4AE26_N95_PCB01_GPRS_MT6226_S01.MAUI_ 06B_W07_04_MP_V32.BIN_B66274F4_20081010-100832.B0X.bin Finished, time used: 181 sec Remove/Install battery now ! But now which one to choose???? From search i got: flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs_01.B0E.bin flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs_02.B0E.bin flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95.B0E.bin flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95_8GB.B0E.bin flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95-8G_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V3 2_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V 32_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V 32_16m_En_Ru_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar_ver2.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_ver2.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_N okia-N95-8GB-RM17_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.b in flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ N95-8Gb_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.bi n flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ N95_16m_En_Ru_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb-RM-17_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb-RM-17_double-slider_L10C_16m_En_Ru_Fr_Es_Hu_It_Ro_De_Cn.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8GB_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_v2.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_v3.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8GB_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_ver2.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-RM13_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-slider_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95-1_32m_En_Ru_Fr_Ml_Id_Vn_Cn_Cn_Ar__w_eeprom.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95_8GB_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _n95_8GB_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _NOKIA_N95_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.b in flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _NOKIA_N95_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Ar.B0M.b in flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ __N95_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin End of search (35 found) |
10-10-2008, 15:29 | #7 (permalink) | |
10-10-2008, 18:35 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can select any of them, better select file with langauges that you need. If first file is not Ok you need to use another one etc. So you will be able to find firmware that is suitable for your phone. |
10-14-2008, 06:47 | #11 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | I have tried may FLASh file but all of them are giving me the same PROBLEM... the Display become like TV but you can see the the FONTS.. its like Windows Contrast Theme... If i flash with it own Flash file it become OK. What should i do NOW??? |
10-14-2008, 15:36 | #12 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Ok problem SOLVED... but flash file was not located on the SERVER. Today by great chance a CLIENT being a CHINA phone n95 same look with the above MODEL am referering to, but the software is differnt and does not have the problem of SIM card. So i copy its FIRMWARE and send it to the PHONE ... and EUREKA... the phone is working and the problem of SIM is GONE... ProbleM : Freeze on Pin Code Accepted Solution: Flash with, KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN_20081014-160536.B0M.bin |
10-14-2008, 15:45 | #13 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Hello SIR, i was thinking about SOMETHING if the above solution make the phone work again mean that i flash the phone with eeprom of the other phone also.. becasue i read the other phone FULL FIRMWARE... Meaning that the flash file in server are FULL or only FIRMWARE?? |
10-15-2008, 03:08 | #15 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Ok thank you. So you do not think that my problem was not solved because i flash only FIRMWARE and not eeprom with the FIRMWARE on the Server? So can you post FIRMWARE with eeprom ? |
n95 with 1.04 error and with 1.03 unlock ok | balanel | JAF No Tp Unlocker by Cinek | 3 | 02-26-2009 15:37 |
6230i hang and turn off, without sim ok... please help | .:.GSM-ANGEL.:. | Nokia Digital Core Technology 4 ( DCT-4 ) | 9 | 04-18-2008 12:47 |
n95 without pin ok, with pin hang | Proxy | Infinity-Box | 4 | 03-25-2008 02:22 |
8380 with sim no power but without sim ok. | Softway | LG | 11 | 04-04-2007 10:29 |
Rel. 5.00 with only one provider without PIN ? | dadleit | Sim Cloning and Scaning | 16 | 04-13-2003 11:07 |
