sigmatel s90i dead due to software sigmatel s-90 is shortcircuit by charger , than i replace power ic 6318 and cpu 6226 than phone detect and formate but phone is still dead....... in infinitybox flashing with new file but no result, infi. details as under..... COM3 [VCP1] selected module v3.09 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FC41:59F0 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V05_EnFrArRuSpPeVi_sigmatel, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ........................ detect standard ffs/eeprom location pass #1... .................................................. ...... detect extended ffs/eeprom location pass #1... .................................................. .. detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL.BI detecting firmware build... .................................................. .. firmware build: áT600_V05_EnFrArRuSpPeVi_sigmatelT600_V05_HW2009-04-2916-37 detecting product-id... .................................................. .............. done detecting languages... ........................................... language parameters detected detected languages: En Ru Fr Es Vn Farsi Ar Finished, time used: 1 min 38 sec Remove/Install battery now ! any have solution for thise ??/ |
no any have solution ??????? |
hello! try few more flash files available on support. please keep in mind that it also can be fault of bad soldering 6318 |
