04-15-2010, 20:40 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 522123 Status: Offline Thanks Meter: 44 | sigmatel s98 pls provide me eeprom of sigmatel s98 ver is :: T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S90i_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M pls help. its urgent. |
04-16-2010, 13:11 | #3 (permalink) |
Member: 522123 Status: Offline Thanks Meter: 44 | s98 sir it shows " not calibrated" i have already flashed the set and use all option in calibration area in infinity. and i have also tried in spiderman box. but problem not solved. sir i know that by writing eeprom file problem will be solved. bcz i have solved this problem in s88 by writing eeprom file. pls sir provide me eeprom file |
04-16-2010, 15:51 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
04-16-2010, 20:35 | #5 (permalink) | |
Member: 522123 Status: Offline Thanks Meter: 44 | Quote:
and i need eeprom of ver T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S90i_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M pls sir help me | |
04-18-2010, 06:59 | #7 (permalink) | |
COM12 [VCP0] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100108-230858.B0Msigmatel s98 skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B14C:642C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 7 min 39 sec Remove/Install battery now ! ==== [4/14/2010 12:26:59 AM] ==== COM12 [VCP0] selected module v3.11 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100108-230858.B0Msigmatel s98 loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 29 sec Remove/Install battery now ! ==== [4/14/2010 12:27:53 AM] ==== COM12 [VCP0] selected module v3.11 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100108-230858.B0Msigmatel s98 loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 3 sec Remove/Install battery now ! ==== [4/14/2010 12:28:31 AM] ==== COM12 [VCP0] selected module v3.11 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__fullflash_20100108-230858.B0Msigmatel s98 loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B14C:642C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 1 min 16 sec Remove/Install battery now ! 1. read full flash from phone 2. make [repair "Code CRC Check Error" during flash] box checked 3. flash phone with file that was read | |
04-19-2010, 09:52 | #10 (permalink) | |
i guarnteed my problem 100% will be solved | |
04-19-2010, 16:43 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please modify your main infinity box accoring pinfinder user manual. there must be diode removed. after that test mode operation will work better |
Sigmatel S-3 Headset Mode | rkinfo_imran | Chinese Models & Cloned Phones | 55 | 01-28-2012 08:42 |
sigmatel v88 pinout | Parminder Singh | Infinity-Box | 14 | 03-06-2010 10:50 |
sigmatel s3 camera module not ready | jobykjoseph | Chinese Models & Cloned Phones | 63 | 10-07-2009 15:49 |
Sigmatel Camera Problem | ka jagan | Chinese Models & Cloned Phones | 10 | 09-19-2008 22:08 |
Sigmatel S-3 | sahil00150 | Chinese Models & Cloned Phones | 0 | 05-03-2008 11:52 |
